which throttle body to go with
Old Nov 3, 2007 | 08:18 PM
lilman8403's Avatar
Question which throttle body to go with
I am replacing my throttle body as it is leaking. I have only found two. Buschur and works. any thoughts on which to get. i will have buschur port my manifold as well.
Old Nov 3, 2007 | 08:20 PM
EvoDan2004's Avatar
b/r is cheeper i beleave. and its the same thing. if he is porting your manifold you miles well have him do the t/b to port match it to the intake manifold. plus your only paying shipping to him and back instead of shipping on a manifold to b/r and back and a t/b to works and back. you will save alot more money and everything will be port matched to each part.
Old Nov 3, 2007 | 08:36 PM
lilman8403's Avatar
thanx for the info, my buddy went with buschur and was happy. i think i will go with them. the port is only 75 for the intake manifold.
Old Nov 4, 2007 | 01:29 AM
Erik@MIL.SPEC's Avatar
Contact WOT on the forums. He has 20 years experience building and tuning race engines for IRL, ALMS and CART. He does 65mm throttle bodies. You can't go wrong with WOT (Aby).
Old Nov 4, 2007 | 01:39 AM
Johnboy1065's Avatar
when your TB leaks do you get a squealing noise during acceleration? just wondering because mine does that.
Old Nov 4, 2007 | 05:13 AM
mudduck's Avatar
From what I have read, it's not who ports the TB the best, it's who matches the TB porting to the porting of the intake mani...
IMHO, the main thing is to have the same shop (assuming they are competent) do both for best results.
Old Nov 4, 2007 | 05:42 AM
evo@24psi's Avatar
Im going with WOT. Seen his work and is nice. They are right though, only minor gains if Intake Mani isnt port match with it.
Old Nov 4, 2007 | 05:46 AM
Evoryder's Avatar
If the TB is leaking why not buy the works high pressure seals? or you just wanna go all out?
Old Nov 4, 2007 | 09:45 AM
lilman8403's Avatar
i can't hear it over my intake and blow off valve. i did a boost leak test and that is when i found it.
Old Nov 4, 2007 | 09:46 AM
lilman8403's Avatar
i know i can replace the seals, i just wanted to go all out.
Old Nov 4, 2007 | 09:47 AM
lilman8403's Avatar
yeah i recieved and e-mail from WOT and this process was explained very well.
Old Nov 4, 2007 | 09:48 AM
Evoryder's Avatar
...i've heard good things about ported throttle body and manifold...especially throttle response
Old Nov 4, 2007 | 09:53 AM
20Grockit's Avatar
i would def. go with the buschur. i just got a hks kansai int. mani and im thinking about gettin a tb from them
Old Nov 4, 2007 | 09:54 AM
lilman8403's Avatar
thanx 20grockit
Old Nov 4, 2007 | 09:57 AM
20Grockit's Avatar
no prob and good luck with your install
