Clutch
Old Nov 5, 2007 | 09:02 AM
frycztech's Avatar
i haven't heared of anyone talking about the custco much. anyone have the clutch any input?
Old Nov 5, 2007 | 09:06 AM
frycztech's Avatar
Originally Posted by 06MRV8Killer
Yes the HD for the power you are putting down. It is complete with the new flywheel, all you need to do is buy a new TOB and get it installed (properly by someone reputable is key dont skimp on aving $ on the install go to someone who has done a bunch of them if possible) and then keep an eye on the engagement (pedal engagement adjustment to make sure it properly disengages once it starts to break in) of it which you can also search about on the site.
I bought mine from http://www.speedelement.com/ at a good price. Very fast shipping from Cali to FL I was impressed with them.
I was thinking about installing in myself since i did everything else on my car.
Has anyone done theres?
Whats the easiest way to tell if its disengaging?
Old Nov 5, 2007 | 09:08 AM
timmiii's Avatar
Theres a guy on here that goes by KMXxBadboy, he uses the Cusco on his 500hp (to the wheel) GT35 equipped Evo 8 MR. He hasn't had a single problem with it. T
he only bad thing I can say about both the Exedy and Cusco is that they both make noise, but thats expected with twin plate cluthes. Other than that both are pretty much the same yet Adam says the Cusco makes less noise not sure how though.
Old Nov 5, 2007 | 09:11 AM
timmiii's Avatar
Theres no real easy way, I mean to really check you have to drive your car and see if it'll lock you out or grind during shifting at any gear and rpm. BUT, you can narrow it down by setting the pedal as far out as possible with the rod and then slowly reducing the length of travel of the pedal until it's at the right spot (the spot is driver dependent).
frycztech's Avatar
what noise do they make a whine?
also some people where telling me to get a ss clutch line any thought on that?
Old Nov 5, 2007 | 09:15 AM
timmiii's Avatar
The pedal feels more direct and the when you step on the clutch it'll feel quicker because the SS line doesn't flex under pressure and will remove the restriction pill in the stock line.
The noise is pretty much really loud chatter coming from the discs when the clutch is fully disengaged or when u decel in gear.According to some people its loud and others it's manageable. Some even say it goes away after some time, don't know.
Old Nov 5, 2007 | 09:16 AM
06MRV8Killer's Avatar
The clutch makes a chattering noise nothing to major, it is much more promenant when the A/C is one but you only really hear it when you are sitting still. (Slightly louder than stock)
I dont have the SS line but I plan on getting one. I dont really know what the advantage of it is.... Anyone on this>?
Old Nov 5, 2007 | 09:17 AM
frycztech's Avatar
I have been looking at both and they custco one everyone is talking about is the twin plate?
iam looking on speedelement and i dont see where to get the tob from.
any other place people been getting the exedy or the custco from?
Get the TOB from the stealership or lancershop.com
Old Nov 5, 2007 | 09:23 AM
frycztech's Avatar
I see on lancershop.com they have a stock tob and a act one what one dose everyone recommend?
Old Nov 5, 2007 | 09:25 AM
timmiii's Avatar
Don't get ACT thats all I can tell you. My tranny is going because of that.
Old Nov 5, 2007 | 09:26 AM
Well you said it yourself that ACT seems like its not the way to go so DONT buy the TOB. Go stock.... No advantage buying the other one anyways..
Old Nov 5, 2007 | 09:32 AM
frycztech's Avatar
ok so if i order the kit from speedelement and get a stock tob is there anything else i need dose it come with the alignment tool?
Has anyone done the clutch install?
Old Nov 5, 2007 | 09:52 AM
Good question, I never looked when I got the clutch for the alignment tool. So I dont know if it has the alignment tool in it. From experience of buying many other clutches for imports they all had the alignment tool. From what I can tell on many site NONE of them say that you need the tool so I think you should be good to go just buy the TOB.
go to www.evomoto.com to get install info if you are going to do it yourself. I had mine done by a friend at a dealer who has done a ton of them. Talk to Scott @ TTP-engineering he is an encyclopedia of information.
Old Nov 5, 2007 | 10:05 AM
timmiii's Avatar
All you need is, TOB (usually vendors include them with the Exedy or Csusco), alignment tool(I think it comes with the clutch) and clutch kit with flywheel.
