Clutch
So I guess the lesson I learned is that I should've stuck to my gut feeling over a shop's word or what people say on a forum like this. Mind you, the stock clutch pressure plate is only 2200lbs of clamping force and the Xtreme is 3300lbs. That's a ****load of a difference if you ask me... In the future IF I decide to make more power, I'll probably go with the Cusco twin plate clutch since the clam force is around 2300lbs the firction plate meterial can make up for the clamp force and hold the power. This clutch I think is more ideal for a 6 speed transmission because it won't shock the internals that badly if you drop it.
mjesenovec
Apr 24, 2009 03:45 PM
