Why stock head bolts are not good for 30+ psi
Last week I spiked over 33.1psi (the ZT-2 sensor is only good for 33.1psi so it was probably around 35psi) and blew the freeze plug out of the water pump. I figured that I lifted the head and pressurized the coolant system. Today I while I was pulling the head, the 2 head bolts closest to the cam gears were only in hand tight, indicating stretched bolts. The gasket was blown out pretty good. The opposite side cylinder showed signs of near failure as well. Hopefully I'll have everything back together within a couple of weeks.
it probably wasn't the boost that killed the headgasket, but more the tune. You probably detonated. What type of fuel where you running for that spike to 33 psi? And are you tuned at 33 psi for that fuel?
The tip in problems you have been having by trying to pioneer the speed density setup on stock ecu is enough to damage the HG. It happens.
I'm not knocking during throttle tip in, its just momentarily lean only when applying throttle during a high vacuum condition. There is also no sign of detonation, just stretched head bolts that allowed the head to lift.
I'll be replacing the HG, studs, timing belt, water pump and main seals just to be safe. Everything else looks fine. No cracks, holes or warpage as far as we can tell.
Jerry
Jerry: You're gonna scare the poor guy! Why do you say that he'll need "plenty" of machine work? Other than checking the cylinder head deck surface for flatness, just what additional machine work might need to be done?
