CEL Fix Installed and Still SES Light on...
Old Nov 5, 2007 | 05:08 PM
vegasevo9's Avatar
Guys,
Need help. I have istalled the CEL fix that I bought from Gruppe-s. I have an Helix downpipe, stock cat and Greddy Ti-c. I have gone to autozone and it showed 02 sensor...
Old Nov 5, 2007 | 05:23 PM
JDMCT9MR's Avatar
You have to reset the check engine light.
Old Nov 5, 2007 | 05:31 PM
vegasevo9's Avatar
I did that twice already..... Unplugged the negative wire overnight...
Old Nov 5, 2007 | 05:33 PM
kreionic's Avatar
why are you getting that cel with the stock cat?
Old Nov 5, 2007 | 05:41 PM
edardnaekim's Avatar
yea what he said
Old Nov 5, 2007 | 05:42 PM
dubbleugly01's Avatar
must be wired up wrong???? You shouldn't even need a cel fix on the stock cat. Whether you have a dp/cat back or not, if the stock cat is in place, you shouldn't need the cel fix.
Old Nov 5, 2007 | 05:43 PM
vegasevo9's Avatar
I was asking the same question...
Old Nov 5, 2007 | 05:45 PM
but even with the cel fix it shudnt go off because it only triggers when there is too much exhuast flowing through it not how little rite??
Old Nov 5, 2007 | 06:22 PM
hk2ronin's Avatar
I thought the electronic cel fix didn't work on the IX's just the VIII's. Try the spark plug antifouler mod in the how to section-easy fix and its under $3.
Old Nov 5, 2007 | 06:52 PM
ooohhh he has the electronic one
Old Nov 5, 2007 | 07:06 PM
JDMCT9MR's Avatar
Why not get the drilled out spark plug defoulers like everyone else.I have a Perrin 3" HFC and the defoulers and have had the HFC on my car for about 4 months now and no CEL.
Old Nov 6, 2007 | 02:26 AM
vishus7's Avatar
since you have a stock cat why not try removing the cel fix. what is the condition of your cat?
Old Nov 6, 2007 | 11:59 AM
vegasevo9's Avatar
I did not have a CEL fix at first and it sill lit up... I only have 6000 miles.
Old Nov 6, 2007 | 02:01 PM
Balrok's Avatar
Did you buy the one under "test pipes and cats" off of gruppe's site?
http://www.gruppe-s.com/Evo/evoex.htm
If you did you don't need it with the stock cat, using it with the stock CAT still in place will throw a CEL also because you have too LITTLE flow instead of too MUCH. Also note this is the mechanical fix NOT the electronic one. In this case your still relying on your actual O2 sensor to function. However you stated that you got a CEL before the "fix" but was it on before or after you put the rest of the exhaust on? Do you think you damaged it when taking it out/putting it in? Did you even take it out being you still have the stocker?
TRK_RDY
Feb 14, 2016 02:23 PM
The hundreds.
Jul 26, 2008 07:39 PM
mihaley
18
Jun 7, 2008 05:44 PM
Gruppe-S
Sep 26, 2007 11:22 AM
supersupra
11
Sep 12, 2006 08:08 PM
