ugrading injectors
Old Nov 5, 2007 | 07:24 PM
StlEvo05's Avatar
ugrading injectors
So I know that stock injectors are pretty much maxed out from the factory. I havent been able to get a good amount of information about what is a good upgrade from teh stock 540s. I was thinking about 780s but I keep seeing 640 and so on popping up. Im looking at getting about 80 ~ 85% duty cycle under WOT conditions while running 21 ~ 22 PSI . I'd like to keep the stock turbo as long as possible since I enjoy the quick spool of the stocker.
Thanks!
Terry
Old Nov 5, 2007 | 07:32 PM
dubbleugly01's Avatar
stock injectors are fine for the stock turbo. You won't need to upgrade injectors until you outgrow the stock turbo.
Old Nov 5, 2007 | 07:41 PM
sparky's Avatar
^^ +1+^^
Old Nov 5, 2007 | 07:46 PM
StlEvo05's Avatar
reason why I asked is because I'm seeing 90 to 97 % duty cycle at WOT. I havent done anything with the stock fuel map. Im just mainly concerned with over running my injectors.
Old Nov 5, 2007 | 08:14 PM
KevinD's Avatar
do you have a walbro fuel pump? and what is the AFR at WOT? both of those can make a big difference on your duty cycles.
Old Nov 5, 2007 | 08:28 PM
Tpayne84's Avatar
Yup
Old Nov 5, 2007 | 10:39 PM
Inprogress's Avatar
Well even with a walbro pump I was seeing IDC's of about 96+ and once even hit 102 with afr's in the low 11's high 10's at full throttle around 7k+...I went ahead and did the upgrade, it doesn't really cost much and can add a lot of room to grow for future mods/upgrades.
Old Nov 5, 2007 | 11:56 PM
StlEvo05's Avatar
I dont have a Walboro, I'm picking one up soon, however when I order one Id like to get the injectors at the same time so I can get my fuel system out of the way for the time being. Inprogress, has about the same idea, I dont want to just get the fuel pump and have to wait to retune for larger injectors.
Old Nov 6, 2007 | 04:50 AM
sparky's Avatar
StlEVO: Weird that you should be maxing out the stock injectors on the stock turbo. What is your complete modlist and how much boost are you running? Also, what method are you using to arrive at your IDC numbers.
Old Nov 6, 2007 | 07:52 AM
tvor's Avatar
I know you
EmirEvoEight
14
Nov 2, 2016 06:20 PM
mrfred
Apr 17, 2015 09:38 AM
twinturbogreg
14
Nov 17, 2010 08:52 AM
Gotboost36
Aug 7, 2009 05:13 PM
MalibuJack
May 23, 2006 04:48 AM
