View Poll Results: Did Mitsubishi screw up on the clutch?
Yes, You screwed the pooch
483
61.69%
No, The clutch is fine.
300
38.31%
Voters: 783. You may not vote on this poll
Did Mitsu screw up on the clutch
it has been mitsubishi's clutch since the galant VR4, evo I-VIII, but if you drop your clutch everytime, wear on these parts are exponential, unless you know how to adjust it everytime you feel like it is slipping, which I have been preaching on previous threads.
Guys ask any pro, YOU CAN"T DROP THE CLUTCH LIKE ON A FRONT WHEEL OR REAR WHEEL DRIVE CAR,its all wheel drive and its a rally car,not a dragstrip car,come on now,ask any professional,not some guy whoraced a few races and calls him self a pro.I think Mitsu.designer know what they are doin better than us,thats why they get paid the way they did, so this tread is a direct insult to the people who designed,put this car together,and fought to get it in the states just so people ca complain and *****!I would hate to be them and read this!
Originally posted by slt
From what I've read, the clutch is fine. The problem seems to stem from a weak pressure plate and a valve that slows clutch engagement.
All the people with low miles it's fine if you have no problems yet. I am not talking about hard launches, either. We'll see how everyone's clutch is after 10K or so.
since the clutch normally wears out, it is important to check for the clutch pedal travel, at what point in the travel it engages(car is moving) and yet easy to change the gears. since our clutch is not the cable wire type instead a fluid type, adjustment is under the dash, where the rod and clevis pin is connected to push the master cylinder. there is no adjustment in the slave cylinder as some would like to believe. adjusting this rod by shortening it to push the master cylinder, is by turning the rod once you have loosened the lock nut. it will make the clutch engage quicker and prevent slippage.
Originally posted by leonard_shelby
4,500 miles ... no clutch issues ( other then just a bit chatter when slowly pulling out ). Other then that, seems great.
All the adjustment at the pedal does it determine how much freeplay the rod has to the clutch master cylinder. More freeplay doesn't mean more clamp from the pressure plate unless the hydraulics were adjusted to the point of preload to begin with. The pressure plate at 2200lb is pretty strong and the disc friction material is the good stuff out of Japan (same as RX7TT, WRX, etc.) so I think the restrictor in the hydraulics has a lot to do with it. A stronger pressure plate will help but I don't think that's the problem folks are having with premature wear.
Do you not agree?
A good pressure plate load will clamp down on a clutch even if it is slipping, where as a weak clamping force will allow the slippage to go on longer. No one with the restrictor has reported back on this forum whether they had to replace the clutch even after the restrictor removed. Not all the failures seem to be from hard launchers or from 1 launch glazing the clutch so bad that it no longer grabs properly.
So ACTman is it your belief that the reistrictor is the real cause of the premature failures and not the lack of clamping force from the pressure plate? Not all of us dump the clutch at 5K and I still feel the clutch will not last as you would expect. The other issue is the radial springs in the clutch disk will see harsher loads with the resitrictor out because it is no longer getting any help from the hydraulic circuit. I have seen my fair share of broken springs or springs partially exiting their retainers. That is a potential down side to the restrictor removal. Either way the clutch fails, though.
I want to thank ACT for coming on this forum and giving feedback.
Obviously, many of us knew who they were and the quality of their product. I am glad they are looking into this issue and coming up with a reasonable solution.
