So whats the trick? Oil pump sproket bolt w/race balance shaft.
Ok I am in the middle of assembling a new engine and working on the timing belt components, I have eliminated the top balance shaft and the oil pump shaft has been lathed off smooth (Thanks AMS). My question is what’s the trick to now hold the oil pump sprocket to get the bolt tight (40ftlbs +-3lbs)?
Thanks in advance,
GTVEVO
Thanks in advance,
GTVEVO
Put a portion of the oil pump balance shaft that does not ride on the bearing in a vise to hold it still while you crank it. I always use red loctite in this application for extra security.
Red locktight has been my close friend for sure!
I'm not expert but once the front cover is on how are you going to hold the balance shaft in a vice?
I think when you have balance shafts in you put a screwdriver in the hole on the side of the block to stop the sprocket from spinning to tighten it down. Without balance shafts I'm not sure how you do it. Just wedge a screwdriver in somehow to stop the sprocket from spinning?
(Be aware I am a complete novice and don't know what I'm talking about)
Thanks in advance,
GTVEVO
Thanks in advance,
GTVEVO
BTW,OT,how much did AMS charge you to turn down your balance shaft as I had mine done by a friend and his charge was $75.00 if anyone is interested.
The proper way to do it is while the front cover is off. I'd recommend removing it and doing it right. If you're really a glutton for risk-taking, I'd recommend as a second possibility taking a section of your old timing belt , a good band clamp, and creating your own "wrench" to fix the sprocket in place while you torque the oil pump to spec. Make sure you keep the gear properly located while you do it, so your torque number is not affected. I second the lock-tite.
Thanks for the option, I understand all of the things no to do and I understand that this is a vital part that cannot be damaged this is why I was asking if there was any trick because I didn't know of any so I wanted to hear if any others had done this after the front cover has been placed on.
Thanks
Thanks
Replace your oil pump and hopefully not your motor when the oil pump fails prematurely. They work great on DSM's but not so good on the evo.You do a "search" on oil pump failures and then you will see that the added support by using a turned down balance shaft helps increase oil pump life.Not saying that spinning the oil pump over 2000 rpms faster then they were designed to spin is not causing the oil pump to fail but the full support from the balance shaft does nothing but help
There's no hard evidence that a properly done BS removal reduces your motor's life, but I agree with turboDan that a turned down shaft probably does not hurt.
One think you can probably take for sure is that without the other balance shaft, you're less likely to have its balance shaft bearing freeze up and destroy your motor.
I typically don't put balance shafts back in a car and when I'm working on one with balance shafts its a 6 bolt motor. However you should be able to clamp on the balance shaft with vice grips. Else tear it out and do it right on the bench. Brake cleaner in all the treads, compressed air, and red loctite when your done. Put a new gasket on it and copper spray is **** for those gaskets. All my motors are bone dry and when your sporting a 90' dsm that doesn't drip a drop of oil that pisses people off.
I'm curious why are you guys so insistent on loctite on the oil pump sprocket? What would happen if the oil pump sprocket retaining nut came loose?
And let me just clearly ask again, is the OP's question in this thread how to tighten the nut on the oil pump sprocket? And was the answer given to put the balance shaft in a vice... then that oil pump gear won't spin, which causes the gear with the shaft which connects to the oil pump sprocket not to spin. Therefore you can torque down the oil pump sprocket.
In the case of the stubby, you can do the same thing and put the stub in a vice.
Another option is torquing it down once you have the timing belt on and you have tension on it. One of those things you have to note down on your "Tod Do" list before cranking the motor.
