where goes engine oil travel in order?
Old Nov 10, 2007 | 02:32 PM
Profoxcg's Avatar
Exclamation where goes engine oil travel in order?
Sorry for the double post,
When the engine comes out hot from the engine block where does it go?
does it go the engine cooler through the engine cooler feed line then gets cooled, then goes to the oil filter and then though the oil pump and back into the head?
A: Does it go to the filter > oil cooler feed > oil cooler > oil cooler return > oil pump > engine > cycle completed... etc.
B: Does it go to the oil cooler feed > oil cooler > oil cooler return > oil filter > oil pump > engine > cycle completed... etc.
The reason I ask is because by knowing this flow then many people can make a good educated guess on to which one the two taps on the oil filter bracket connect an oil temperature and oil pressure sender.
Im making the assumption that the feed line bring oil in the cooler and that a return line carries it out. correct?
Old Nov 10, 2007 | 03:27 PM
Profoxcg's Avatar
so i searched the web for a while...
the oil gets pumped from the oil pan into the engine block, then i go out into the filter then the cooler?
Old Nov 12, 2007 | 11:56 AM
Profoxcg's Avatar
come one, someone help me...
Old Nov 12, 2007 | 12:17 PM
topnitroracer's Avatar
I think it should be your option A but I do not know for sure how they designed it. Filtering the oil first would serve two purposes. First, you would keep all the debris out of the cooler. Second, higher temp oil will flow through the cooler with less restriction.
Old Nov 12, 2007 | 02:25 PM
Redline-Z's Avatar
Veteran: Air Force
I am running my Oil temp sender in my blank by the oil filter and the highest temps I have seen is 180F, even on the dyno/highway pulls it still read 180F. This seems way low for Oil temps, anyone know why or have an explanation?
Old Nov 12, 2007 | 08:29 PM
Profoxcg's Avatar
which one of the two taps did you use? I was told one is before the oil goes into the cooler (the higher one towards the side/front) and the other after the cooler
Old Nov 15, 2007 | 06:17 AM
Redline-Z's Avatar
Veteran: Air Force
I don't know off the top of my head but it is configured only one way due to the fact my pressure sender is in the other one.
Anyone else provide any info on low reading oil temps in the blank plugs. I am seeing 180F when I am on it.
Old Nov 15, 2007 | 06:58 AM
Profoxcg's Avatar
well I was asking because I am doing the same setup, maybe you should try inverting the sensors. I mean my engine bay reached 165F-180F on a hot day here in FL. I know this because the oil temp sensor is sitting in then engine bay as we speak close to the block. so I am sure the oil is much higher then that.
Old Nov 15, 2007 | 07:20 AM
evoix10's Avatar
Well i have the stock oil temp sensor and im sure you guys know the oil drain plug and sensor is one unit.
Redline-Z: accorrding to my stock gauge i get about 65C to maybe 95C which is 149F - 203F and it's never gotten higher than that no matter how hard i drive hopefully that helps a little
Old Nov 15, 2007 | 07:41 AM
Infinity's Avatar
95? Hmm, my stock oil temp gauge has never registered over 75, maybe 78. Regardless how hot it is and how much an asshat I've been with the car.
Old Nov 15, 2007 | 09:20 AM
evoix10's Avatar
It may have hit 95C. i drove it from cali to michigan and in the nevada area it was getting close to that. but here in michigan i get about what you get 75ish most of the time
STM Tuned
May 5, 2019 12:51 PM
migs647
Mitsubishi TC-SST Discussion
77
Mar 7, 2019 04:57 PM
PhantomBlackEVOX
Jan 28, 2015 07:28 AM
Archlegan
Lancer Aftermarket Forced Induction Tech
Nov 26, 2013 05:35 PM
Pale Horse
Jul 26, 2013 09:47 PM
