Boost Leak from Throttle Body?
Old Nov 12, 2007 | 08:13 AM
w8lifter21's Avatar
Anyone experience this? I did a boost leak test because I spike to ~20-21ish psi then slide down to ~15psi. Test found that I have a leak where the throttle cable attaches to the throttle plate. If I push up/down/left/right on this part I can hear the air coming out change, sometimes stop for a 1/2 second or so.(Not actually open/close the throttle)
Anyone else experience a leak at this point?
I am pushing/moving this part^^
Old Nov 12, 2007 | 08:20 AM
PATRICK B.'s Avatar
Sounds like TB shaft seals don't it
Pretty typical w/ the stock TB's
Works has the fix.
Old Nov 12, 2007 | 09:27 AM
MasterNater's Avatar
Oh yeah, it's typical. Very first thing I had to fix on my evo, just after bringing it home from the dealer.
The parts you need...
http://www.worksevo.com/store/produc...roducts_id=415
And the writeup...
https://www.evolutionm.net/forums/sh...d.php?t=220264
Old Nov 12, 2007 | 10:06 AM
Aby@MIL.SPEC's Avatar
this is where i have seen 100% of all failed seals....
buy the works seals. that what i use for my 65mm tb's
Old Nov 13, 2007 | 05:59 PM
JKav's Avatar
Has anyone ever done a boost leak test while holding the throttle OPEN? This is all that really matters. The throttle is never closed when there's full boost.
w8lifter21, do the boost leak test again with the throttle open. If it still leaks, THEN there's a problem. If not, then don't worry about it.
Old Nov 13, 2007 | 06:29 PM
RazorLab's Avatar
Every single boost leak test I have done with failed throttle body seals leak with the throttle closed or open. Just my personal experience. I've had some so bad they wouldn't even hold 5psi.
Old Nov 13, 2007 | 09:17 PM
LoBoost's Avatar
With less then 3000 miles on my car my throttle body seals leakedt only 3psi opened and closed,replaced them with works 25psi seals and it holds boost way better.
Old Nov 13, 2007 | 09:24 PM
Evoryder's Avatar
Throttle body seal...fun lil project... got mine from WORKS... high pressure seals.
Old Dec 16, 2007 | 04:25 PM
diiirk@AwdMotorsports's Avatar
will there be a significant power loss with this leak. i leak tested my car and couldnt get passed 5 psi. it was coming out of the TB. Boost holds rock solid though?
Old Dec 16, 2007 | 04:33 PM
RazorLab's Avatar
Your turbo is overspinning to meet the requeted boost levels. So while your gauge says the same boost, the turbo is spinning overtime to meet the same boost levels with that leak.
in other words, your turbo hates you.
Old Dec 16, 2007 | 04:39 PM
well then maybe that can possibly explain why my turbo spool sounds alot louder. and why i feel like im boosting but not really making much power
Old Dec 16, 2007 | 04:53 PM
evovin's Avatar
good info here!
Old Dec 16, 2007 | 06:04 PM
LayinLo's Avatar
Gonna have to replace mine too.
Old Dec 24, 2007 | 06:47 AM
w8lifter21's Avatar
Can these leaky seals be the reason why I only get 14.5mpg city and 16mpg highway? I only have a filter and HKS turbo back.
Old Dec 24, 2007 | 08:29 AM
asr10 user's Avatar
Is a leaking throttle body a common issue?
