6,7,8, & 9 transmission?
Old Nov 13, 2007 | 03:56 PM
dk-2020's Avatar
Does anybody know if I could use a 7,8 or 9 USDM tranny for a 6 JDM RHD? Possible 6 speed swap on a Evo 6? but 5 speed works too. I know that the gear ratios are different but do they share the same case since they share the same engine? Thanks.
Old Nov 14, 2007 | 07:51 AM
94AWDcoupe's Avatar
The tranny is the same. Any tranny from 4-9 can work. The 6-speed may have clearance issues in the frame and would require all the normal swap parts.
I know what car you are working with. Are you potential buyer or seller? You can buy the cases from 8 at the dealer for around 650 for pair. If case is cracked thats what should be done to save that low mile tranny. You could also contact shep racing or TRE for uses cases for half that price.
Old Nov 14, 2007 | 09:35 AM
downshift411's Avatar
the tranny on the evo 4/5/6 share the same tranny housing the evo 7/8/9 uses a bigger tranny. havent you looked in the eninge bay. obviously the evo7-9 has a bigger bay.
Old Nov 14, 2007 | 02:03 PM
94AWDcoupe's Avatar
I have evo4 and evo8 trannies here in my garage. They are the same dimensions.
eazlan
Dec 28, 2016 09:46 AM
Derek888
15
May 21, 2016 04:55 AM
foxbat
Mar 6, 2013 07:59 AM
AboodsEvo
Aug 17, 2010 08:59 AM
CityKnight
Lancer Tranny/Drivetrain Tech
12
Jan 8, 2008 12:51 PM
