Bosch 044 Noise
Old Nov 14, 2007 | 04:53 AM
gtm_maxwell's Avatar
Question Bosch 044 Noise
Is that for External Bosch 044 will be a lot of noise... As I have install a external Bosch 044 with External tank..
will it help reduce the noice if make it(Bosch 044) intank?...
Have any one done it before.. will it help or is that my 044 have problem..
Any one have try to make the 044 intank?. does it help lower the noise alot?.
Do you use Collector tank(SARD) and put the Bosch 044 intank?
any suggestion are welcome...
Old Jul 4, 2008 | 05:20 AM
Ducu's Avatar
bump
Old Jul 4, 2008 | 05:43 AM
fid's Avatar
fid
In the VW world there were alot of people installing boxes over the Bosch pumps to cut down on the noise with great success. Try isolating the pump on some rubber and make sure you don't have a fuel filter before the pump because that will make it nosiy. From my experience the Walbro external is a bunch more noisy then the Bosch 044 so no option in swapping pumps. I wish a vendor would try and fit the 044 to the evo fuel pump assembly because it is a FAR superior pump when it comes to reliability and will outflow it anyday of the weak when you start uping the fuel pressures .
manden
E85 / Ethanol
Feb 26, 2014 02:29 PM
jdfrank81
Jun 25, 2012 07:08 PM
norcalSRTrida
50
Oct 15, 2010 08:12 AM
joyce1bro
14
Jul 15, 2010 01:27 AM
Oracle1
Jan 25, 2009 04:20 PM
