264/272 HKS cam timing for best emissions results
Old Nov 14, 2007 | 09:32 AM
ruzs's Avatar
Title says it all,
I would like feedback on what to set my cams at in hope of passing an emissions test that failed due to high hydrocarbon results.
I will also put the stock cat back on to get the best results and change the plugs.
Thanks for the help,
Sigfrid
Old Nov 14, 2007 | 09:37 AM
Ted B's Avatar
Try advancing the exhaust cam 2 degrees, and retard the intake 2 degrees.
Old Nov 14, 2007 | 11:41 AM
ruzs's Avatar
Confused
Hey Ted,
Thanks for looking into this. Could you please clarify?
Should I set it to -2 I / +2 E
It's easier for me to have the final setting as I am not sure if you meant move them X degrees from where they are set at now.
Thanks,
Old Nov 14, 2007 | 11:48 AM
Ted B's Avatar
-2i / +2e is correct.
Old Nov 14, 2007 | 12:59 PM
ruzs's Avatar
Timing
Thanks Ted.
I trully appreciate your assistance.
Sigfrid
Old Nov 14, 2007 | 03:53 PM
whitey4d's Avatar
Im just curious but is this a dyno test or 2step idle test with a 5 gas analyzer? Im a Certified Emission Inspector in Pennsylvania. In different conties there are different tests. ALso the year of the vehicle gets taken into account also. Like less populated counties just use OBD scan, visual, and gas cap tests. Then the 5 gas analyzer up to the Dyno around Philly and Pittsburgh.
Old Nov 14, 2007 | 04:18 PM
gtm_maxwell's Avatar
-2i/+2e
About the setting for 262/272 cam for EVO... with this setting -2i/+2e will it push
the power gain into the front(Early RPM) or rear(high RPM). As different setting
will move the power curve...
What will this setting do to the Power Curve?
captinnitro
Feb 27, 2016 01:05 PM
Attack Vector
Northwest Region
20
Jan 30, 2011 10:09 PM
5k6
Midwest Region
13
May 16, 2010 04:01 PM
jamsky
May 9, 2008 11:06 PM
Infini IV
Oct 16, 2004 09:07 AM
