buschur fp3065
Old Nov 15, 2007 | 08:20 PM
TREVORSEVOVIII's Avatar
buschur fp3065
just one more question trying to make sure i do whats right for me, what size injectors would you have to run with this kit, i love the power you can make with this kit its right where i would wanna be, but this is my daily driver and gas milage will play into my decision, so what size injectors would be needed to make 400awhp on 93 octane with this kit and how bad would it hurt my gas milage, thanks alot guys
Old Nov 15, 2007 | 08:28 PM
joseph k's Avatar
not sure how bad it would hurt your MPG, but after speaking with Jarrod it seems as though 780's are enough
Old Nov 15, 2007 | 08:38 PM
Brian's Avatar
880CC Injectors
mileage shouldn't vary much I get ~22mpg with mixed driving on mine.
Old Nov 16, 2007 | 03:30 AM
riceball777's Avatar
720's will be more than enough for 400whp. but dont waist your money and just get 880's if you want to max of the turbo.
also if anything gas millage should get better when you switch to a bigger turbo because of the lag. your going to be in boost much less. with this turbo your only going to be in boost if you want to. with the stock turbo you can be driving normal and you hiting boost. gas millage will only suffer if your always on the gas.
Old Nov 16, 2007 | 04:01 AM
sparky's Avatar
Spend the extra dough and get the HTA compressor upgrade from Buschur Racing for your 3065. Either 850 or 880 injectors should be enough to feed that badboy.
Old Nov 16, 2007 | 06:04 AM
Danner's Avatar
I think this is funny. Worrying about max power but still keep good gas mileage and what injecters. If you worried about losing mpg than get a different daily driver that gets better gas mileage. "The accumulated extra money you spend on gas could = a cheap daily that gets better mileage"
As stated before larger turbo should increase mpg daily driving, Its also a matter of how your tuned. If you want 400awhp machine that you daily drive, your going to have to make some sacrifices.
No pun intended. I hope which ever decision you make is the best for you. I wish i could make those kind of decisions.
Old Nov 16, 2007 | 10:05 AM
joseph k's Avatar
they said there will not be an hta 3065
Old Nov 16, 2007 | 10:32 AM
PVD04's Avatar
Forced performance can probably make one. It's a compressor wheel and housing replacement. You won't be able to buy it in kit form, but you could buy the kit and ship the turbo to FP for a compressor upgrade.
-Paul
Old Nov 16, 2007 | 11:06 AM
im just gonna stick with the ix for now with meth and get it upgraded to a 20g later on thanks alot guys
Old Dec 6, 2007 | 12:52 PM
yellowEVO21's Avatar
Did anyone confirm with buschur they won't be carrying a hta 3065 kit?
Old Dec 6, 2007 | 02:15 PM
dxbevo9's Avatar
can u shed more light on this upgrade sparky?>
Old Dec 6, 2007 | 03:39 PM
20Grockit's Avatar
id go with something not quite so big for 400 awhp
Old Dec 6, 2007 | 06:31 PM
1slowevo's Avatar
I agree. The 3065 is capable of much more power. if you want to make goog pump gas numbers, the green might be right for you
Old Dec 10, 2007 | 12:32 PM
As someone mentioned earlier, there will be NO HTA upgrade to the 3065.
I just got a response from jarrod about that.
Old Dec 10, 2007 | 01:32 PM
apagan01's Avatar
I wouldn't be wasting my $ on a green. I'd get a true ball bearing turbo 30.... although greens are good.we have all seen them making those #brs .but. iam working on a build and BR and a friend of mine recomended a 30.. for the same numbers 400-450....
harp12
Feb 25, 2014 07:18 AM
Thomar
Mar 5, 2013 09:09 AM
BoostKid87
Jan 4, 2013 04:58 PM
jid2
30
Feb 24, 2009 12:37 PM
smitty1119
Jun 9, 2007 08:03 AM
