Evos acting wierd an i need help :( battery problems
Old Nov 18, 2007 | 12:42 PM
Kevin Knight's Avatar
left a party this morning and my battery light and parking break light was on. keep drivin then the abs light came on and the srs light came on.
note- i have a oddsey small battery
i have a hks turbo timer and it was reading 10 volts then it when down to 9 and my radio shut off and so did the turbo timmer screen. i knew if i stoped the car the car would probley not start again. drove it back to my friends house and turned it off. then it wouldnt start again. we charged it with a jump pack and it was reading 12 volts. then we drove around and the battery volts slowley went down again. then pulling in the drivway the rpms were real high at nutreal. around 2,500k. i dont think its the alternator because when i was driving the turbo timer light come back on and read 9.3 volts if i was driving at 4k rpm.
i need help i think i need a new battery the battery is 2.5 years old.
Old Nov 18, 2007 | 01:42 PM
need help!!!!!!!!
Old Nov 18, 2007 | 01:54 PM
EvoJoeIX's Avatar
make sure the alternator is charging about 14 volts...
sounds like an alt. to me, cause even if your battery isnt any good, the car can still run off the alternator....
Old Nov 18, 2007 | 02:56 PM
Chemwarrior's Avatar
Take your car to Advance Auto. They can test your battery and alternator to tell which one if not both are bad.
Old Nov 18, 2007 | 02:59 PM
Silver05Bullet's Avatar
its the alternator
Old Nov 18, 2007 | 03:01 PM
bluebyu36's Avatar
your alternator is not charging the car will die in a couple of days the same thing happen to me i drive it for a couple days then it just died
Old Nov 18, 2007 | 04:27 PM
TempeRacerGuy's Avatar
It's your alternator.
Old Nov 18, 2007 | 04:31 PM
smokedmustang's Avatar
Alternator.
Old Nov 18, 2007 | 04:37 PM
edardnaekim's Avatar
hey kevin, do you drive your car with the ligths on ALL the time?
Old Nov 18, 2007 | 04:54 PM
iturregui's Avatar
Try jump starting it and have a friend disconnect the battery while you keep the revs at 2k or 3k. If it shuts off, then it's the alternator. If not then you have a really bad battery
Old Nov 18, 2007 | 06:14 PM
i do drive with my lights on alot. i have yellow fog lights that look really sexy when on. but what would that do?
Old Nov 18, 2007 | 06:53 PM
evo420's Avatar
any extra light stereo etc etc puts more strain on your alternator, I ran one of those electric coolers in my work truck and went thru 3 alternators in a year.
Old Nov 18, 2007 | 06:57 PM
bosco121's Avatar
bring the alternator to auto zone and they will check it out for you. its most likely no good.
Old Nov 18, 2007 | 07:07 PM
dRifT iT's Avatar
do your interior lights do a little light show??? like, flicker?
im saying its the alternator tooo...
Old Nov 18, 2007 | 07:23 PM
but if i drive at 4k rpm the turbotimer comes back on and the volts go up. so is the alternator bad?
