HKS SSQV Ver. 3
Try a Synapse Engineering BOV at http://www.synapseengineering.com/. The is NO DIAPHRAM and is pressure tested to 100psi. My friend running 40psi on his 1g talon is using just one with no problems what so ever.
If you goto youtube and watch it its just amazing at how fast it reacts and no matter how the throttle is used it whistles NOT FLUTTERS!!!
Sorry i didnt understand. The HKS racing does fine partial throttle as well. We've gone through plenty of Mtn. runs that required to run partial throttle of course and had no surging.
here a video of the last track event we went to you can here the blow off valve surging when i am trying to modulate the throttle
http://www.youtube.com/watch?v=cfoX8-3FjuY
http://www.youtube.com/watch?v=MU5Y6d9rh1k
What do you guys think about this????? it seems very interesting this shows the comparison between a HKS ssqv Version 2 and if you search you can find a comparison with the tial 50mm
these will give you an idea of partial boost/low throttle/high boost/WOT reactions of the TiAL
http://youtube.com/watch?v=8-JTfgpFKrM
check that out, then all the response vids
those videos are RIGGED like no other...
correct, too stiff = it will only crack open or open very slow causing surge (if you look at the synapse vids it's a perfect example of what not to do, he uses a spring that is too stiff for the vacuum the car is producing)
so let lets say my version 2 hks ssqv is using to stiff of a spring that why it surgin at times but by using to soft of a spring the BOV might not hold all the boost right for hi boosting cars ?!
Just use your stock BOV. It has no "rating," but it does start to open around 25psi, however, it's nothing that will affect you noticeably, and it will have wonderful part-throttle response.
as far as i know, ours is the only BOV you adjust with a different spring.
