Is this ATS twin carbon any good?
im prettty sure you can buy new disc's from carbonetics in the US or one of the dealers. i see ur in miami call Billet Design (954-975-3557) there wd for carbonetics in ur area. they might be able to help u see if that clutch is any good also
imo id invest in new disc and sand the flywheel
well i spoke to ats tech support and showed them the pics. they said more important is measuring for even wear on the carbon discs with a micrometer (should be more than 2mm thickness and even). in addition, to lay metal plates flat on a metal surface to check for warping. if these two areas are fine, then the hotspots are not significant.
Hey i didnt tell you but plates are $580 a pop thats about the lowest ive gotten it so far. I have a triple disk thats going in that car and plates will be checked and swaped every 10 passes.
mr.alex
61
Sep 15, 2008 03:35 PM
