Shockproof + Amsoil cocktail in 6-speed gearbox
Old Jan 30, 2011 | 08:18 AM
achilles3000's Avatar
Originally Posted by mrfred
I bailed on Shockproof in the gearbox due to the horror stories about parrafin wax clogging up in the oiling hole through the shaft (I forget whether it was the input or output shaft).
That's why the light weight shook is recommended.
Old Jan 30, 2011 | 09:42 AM
mrfred's Avatar
Originally Posted by MJ23FE
Ah, ok. Good to know. What are you currently running now? I've been thinking about running the Redline MT-85. After reading a recent review on here, I want to give it a try. Especially due to its price.
-Jalal
I'm running the Amsoil Severe Service gear oil right now. I'm sure it protects the gear teeth well, but shifting is perhaps a bit worse than the Amsoil MTG. Next up will be the Castrol Syntec that I picked up from Mil.Spec. Hoping to put it in soon.
I was running the shockproof lightweight, but aren't all of their shockproof gear oils susceptible to centrifuging of the paraffin (or is it a moly lube that centrifuges)?
Old Jan 30, 2011 | 11:19 AM
I was running the shockproof lightweight, but aren't all of their shockproof gear oils susceptible to centrifuging of the paraffin?
I heard there's no issues like that even ams dan,and andrew told me it's the best for the evo tranns when pushing good amounts of power.
Old Jan 30, 2011 | 11:31 AM
apagan01's Avatar
mfred
have you tried 2 qts of MTG Gl4 and .8 of AMSOIL syncromesh ?
i think you wont see better results with any other coctail from, high rpm shifts, to super cold temps shiftin ect..
for cars making high torque i would be carefull on these mixes you want something to be always in between the gears without shearing to quick.
Old Jan 30, 2011 | 11:36 AM
MJ23FE's Avatar
I've been using Amsoil MTG in my trans with SVG in my TC and Diff. My trans is very notchy, so I'll be giving the Redline MT-85 a try. I'm going tonsee which Redline fluid works in my TC and rear diff and give them a shot. If not it'll be SVG again.
-Jalal
Old Jan 31, 2011 | 03:57 PM
apagan01's Avatar
I am actually wondering if you tried MTG, it does much better in the tranny than SVG
i think it was Shep who noticed this, but dont quote me.
Old Jan 31, 2011 | 04:23 PM
mrfred's Avatar
Originally Posted by apagan01
mfred
i think you wont see better results with any other coctail from, high rpm shifts, to super cold temps shiftin ect...
Sounds interesting, and I may try it after the Castrol.
I am actually wondering if you tried MTG, it does much better in the tranny than SVG.
I ran MTG for about two years before I tried the SVG. My recollection is that MTG shifted slightly better than the DiaQueen.
When the SVG was fresh, it felt pretty comparable to MTG. Now that the SVG has several thousand miles on it, its been hard to pin down the shifting performance of it. Some days it seems pretty decent, but other days, like today, it seems pretty notchy/grindy. As best as I can tell, when its really cold, it does ok, and when its warm it does ok. Seems like there is some intermediate temperature range where its problematic.
Old Jan 31, 2011 | 08:54 PM
cij911's Avatar
I love the castrol from mil spec...thanks eric
Old Feb 1, 2011 | 07:39 AM
apagan01's Avatar
i never tried SVG in the tranny, however in comparing SVG and MTG now it makes sence why it would do ok in the tranny,
these trannys are something else, reality is i think we are dealing with thermal expansions here from the different temp ranges.
Jacks Transmissions
Jacks Transmissions
58
Feb 3, 2016 12:45 PM
Solo II Evo
Apr 22, 2009 03:08 PM
Appauldd
48
Mar 20, 2009 08:07 PM
Kodiak
Apr 26, 2007 03:14 PM
mrfred
Jul 7, 2006 12:52 PM
