tried Amsoil MTG in IX MR 6-speed
Old Jul 7, 2006 | 11:18 AM
mrfred's Avatar
After 3000 miles of a notchy 1->2 gear shift, I decided to change out the factory tranny fluid and try some Amsoil MTG (GL-4 75W-90). I was hoping it would smooth out the 1->2 shift notchiness, but no such luck. It did somewhat smooth out the 2->3 shift which was only slightly notchy. If it doesn't get any better by the next oil change, I'll have to try something different.
Anyone have good experiences with switching to a non-OEM GL-4 tranny fluid in an Evo 6MT?
Old Jul 7, 2006 | 11:38 AM
Karash's Avatar
It is what I use and the shifting is pretty smooth for me. However, the oil needs to get a bit hot for "butter like shifting" I have found. Of course I am using poly shifter link bushings, base bushings, short shifter and a stillway engine dampener.
Old Jul 7, 2006 | 12:01 PM
DaWorstPlaya's Avatar
The tranny fluid has to get hotter and oil needs to thin out to get smoother shifts on the 6 speed from my experience. Some have been using Pennzoil Synchromesh in the 6 speed trannys for smoother shifts with great success although they do change it more frequently (3k miles)... Pennzoil and BG Synchroshift are the prefered tranny oil for the 5 speed.
Old Jul 7, 2006 | 12:28 PM
rodman's Avatar
Why not for the 6 speed?
Old Jul 7, 2006 | 12:52 PM
Because of the weight and viscosity of the oil ...
5 speed uses 75W - 90 GL-4 and 6 speed uses 75W - 85 GL4
Pennzoil is GL-S rated ....
Personally I recommend using stock Diaqueen oils and driving carefully until the tranny fluid has had a chance to warm up.
mrfred
23
Feb 1, 2011 07:39 AM
mrfred
31
Sep 12, 2010 05:23 PM
sekula
Aug 3, 2009 07:08 PM
RevMatcher
Jun 9, 2009 05:05 PM
sdfontanini
36
Feb 6, 2009 10:33 PM
