uicp issues..
Old Nov 26, 2007 | 04:16 PM
XIEvolutionIX's Avatar
uicp issues..
So heres the story:
On my drive home today i was stuck behind someone going 25 on a 40mph road so of course i passed them, upon passing them i accelerated and hit peak boost and right when i hit it i here a very loud pop, like gunshot loud. so i had to pull back behind the slow driver, pull over and get out to see if its my tires, its not, so i pull back on the road and theres no power, so i pull back over, open the hood and notice the mesh upper intercooler piping completely off of the intake manifold and the throttle body completely exposed. so i got out a screw driver loosened the clamp and put it back on and drove home. My question is why did this happen? Was the clamp too loose? Was there a sudden surge of boost that blew the pipe off? Because recently i had the clutch replaced (which was a mess im not getting into) and i believe this requires removal of the stock airbox and the intake assembly, but im not positive it removes the uicp, infact im pretty sure it doesnt. But they did a pretty sh*tty job putting it back together (lose bolts, missing fastener, etc.) so im wondering if it was the dumbass mechanics fault or not, cause if it was then mitsu is gonna be hearing from me..
thanks for any input
Old Nov 26, 2007 | 04:20 PM
Evo9"Miss Rose"'s Avatar
common thiing with our Cars UICP/LICP will pop off the pipe likes to FLEX underBOOST and the stock clamps at times just cant hold it mine for instant hasnt blown off but others have its basically an easy fix... get some T-clamps install them and call it a day!! nothing to worry about or raise hell about!!
Old Nov 26, 2007 | 04:28 PM
E\/0IXG$R's Avatar
spray some hairspray on the insides of the silicone hoses that connect the hard pipes before you t-bolt them back in place.
Old Nov 26, 2007 | 04:31 PM
well the only reason id raise hell is because they messed up other stuff.
but yet i fixed it im just making sure every things ok.
whats the hairspray do?
Old Nov 26, 2007 | 04:46 PM
Spoolin18's Avatar
The hairspray becomes very sticky, it almost acts like an adhesive. Which in turn, would make it harder to pop off.
Old Nov 26, 2007 | 04:52 PM
ill try it out, thanks
Old Nov 26, 2007 | 04:53 PM
Curt@MrLed's Avatar
Former Vendor
hairspray and good clamps.
Old Nov 26, 2007 | 06:15 PM
JDMCT9MR's Avatar
I had that happen before when I had the HKS BOV and UICP.Now I have the ETS UICP w/ T-bolt clamps and have zero issues.Not a pleasent feeling or sound when a turbo hose or intercooler pipe pops off.
Old Nov 26, 2007 | 06:50 PM
mudduck's Avatar
T-bolt clamps are simply not needed, especially at your mod/boost level (stock).
Put down the screwdriver and take a ratchet with a 10mm socket to that stock worm clamp.
Old Nov 29, 2007 | 11:02 AM
evotuner04's Avatar
15 Year MemberLikedLoved
yeah its common to have that happen, i had the same issue w/the ssqv pipe kit...pos and just tighten it good and you'll be alright
linkbeat
26
May 27, 2014 09:00 AM
white_evo27
Oct 30, 2012 11:09 PM
johntesi
Dec 27, 2009 10:17 PM
Burklow
Feb 26, 2008 09:24 PM
rodman
Jul 24, 2006 07:29 AM
