Evo Experts & HKS GT3240 Turbo
Old Jan 27, 2010 | 11:47 PM
discopotato03's Avatar
I found a pic of a GT3240 and as always its a Garrett one just made to someone elses combination spec .
BTW Tag says GT3240 and 706451-14 which is the cartridge number . Same family as the Garrett marketed GT3582R which is cartridge number 706451-5 .
Turbine housings are easy . What Garrett do is machine their GT30 turbine housings out for use on GT3582R's , what this means is you can take a GT30 turbine housing and do the same thing for the "GT32" turbine wheel and bolt it on . The cropped GT35 turbine , "GT32" if you like an incorrect term , is larger than the GT30 and smaller than the GT35 so go attack a GT30 housing .
If you get on well with a good turbo dealer get them to see if they can order the 706451-14 cartridge and its matching compressor housing , cheaper than paying HKS prices for a Garrett turbo .
Personal choice I suppose but I think you're better off with a T3 flanged turbine housing for that kind of power output and Garrett GT30 turbine housings have that .
Cheers A .
Old Jan 28, 2010 | 12:06 AM
scorke's Avatar
Its a sweet turbo.
30 psi will make well over 500 whp on a properly setup motor.
Scorke
Old Jan 7, 2014 | 04:20 AM
omar82_omari's Avatar
Guys.. Advice needed !
I have evo 8 MR with TODA 2.3 , HKS 3073s Kit with HKS 272 cams. I was wondering if i could do this mix options :
1- TODA 2.3 + HKS 3240 kit with HKS 272 cams or
2- TODA 2.3 + HKS 3240 kit with HKS 280 cams or
3- TODA 2.3 + HKS 3240 kit with in 272 & ex 280 HKS cams or
just replace my hks 272 cams with hks 280 cams and stay with the 3037s turbo kit ?!?!?
P.S ECU : MOTEC M800
southpaw
23
Feb 24, 2021 12:24 PM
MDH-005
Apr 28, 2014 01:23 PM
Mr.IX
20
Sep 21, 2010 03:42 PM
ZevoX
Aug 26, 2010 04:46 AM
Sylent Nyte
16
Jul 10, 2007 01:41 PM
