front axles
Old Dec 7, 2007 | 11:47 AM
Dapper Dan's Avatar
Originally Posted by USP Motorsports
ok front are just the shaft and boots. those are 475.00
the rear comes with hubs, shafts, boots, ext studs.. 1750.00
together they cost 2225.00 for the set
i think he wants to know if the fronts will completely replace his because his are bad...
Old Dec 7, 2007 | 12:03 PM
11secEVO7's Avatar
from what I understand most people don't upgrade all..
just the rears I think
Old Dec 7, 2007 | 01:01 PM
AWD Motorsports's Avatar
if they are bad the upgrades probably wont fix it if its broken in the hubs
Old Dec 7, 2007 | 06:50 PM
chrismnj's Avatar
well i don't know how to figure it out what is wrong. once in while when turning or going over the bumps I hear knocking noise in the front right wheel.
Old Dec 8, 2007 | 01:58 PM
chrismnj's Avatar
bump
Old Dec 8, 2007 | 07:28 PM
chrismnj's Avatar
anybody knows what could it be?
Old Dec 8, 2007 | 07:39 PM
EVOx2008's Avatar
that sounds like a suspension issue.
are you running stock or after market... check the shock and the spring for movement. If its a coil over there are tons of people with experience in that department
David Buschur's Avatar
I wouldn't buy front axles, I cannot imagine you breaking one. We are running 8's on the stock axles in our EVO. I didn't even know anyone made a set of fronts.
When I sold my 1991 AWD Talon to John Shepherd I had 760 passes on the stock front axles. Last year he was still running them.
Old Dec 10, 2007 | 04:55 AM
chrismnj's Avatar
the suspension is all stock
Old Dec 10, 2007 | 02:39 PM
chrismnj's Avatar
David so if it is not a axles what else could it be?
Old Dec 10, 2007 | 06:44 PM
VRSF Tiago's Avatar
there is no hubs in the front ?
I'm guessing there isn't a need considering most of the weight gets shifted to the rear on launch so most straing gets put on the rear wheels.
Old Dec 10, 2007 | 06:46 PM
VRSF Tiago's Avatar
Are the rear axles as tough or did you have to replace those more often?
Old Dec 10, 2007 | 06:50 PM
ive snapped a rear axle with under 700whp so i am sure DB has upgraded ones on the race car.. i dont think he does on the white car tho..
Old Dec 10, 2007 | 07:07 PM
chrismnj's Avatar
OK but anybody have a idea whats wrong with my car?
Old Dec 10, 2007 | 07:11 PM
VRSF Tiago's Avatar
Worn tie rods, dead ball joints or worn sway bar bushings.
The only way to know is to have someone take a look at it. There's only so much somone can tell you about a clunking sound on the internet.
Carver
Jul 18, 2016 02:30 PM
jhoganusaf
Jan 28, 2014 09:25 PM
Sinister_X
May 2, 2011 07:34 PM
civicevo380
Nov 13, 2007 05:41 AM
