axle seals
Old Jan 28, 2014 | 08:42 AM
jhoganusaf's Avatar
axle seals
anybody have any tips on getting the front drivers side axle seal out?
Old Jan 28, 2014 | 10:22 AM
jason42003's Avatar
Use a seal puller, it's not that hard a job. Just make sure you don't seat the new seal all the way in or it will more than likely leak. There's a little lip a couple mm down from the top of the seal, pop it in till that is flush.
Old Jan 28, 2014 | 11:46 AM
jrainwater's Avatar
I had two of those leak (and I did push it in the correct amount where that little mark is) until on the 3rd one I brushed a little gasket maker into the hollow inside part of the seal. That one has never leaked once since installing it. As far as getting the old one out you should be able to pry it out with a long flat head screw driver. Just rest the end of the driver against the inside part of the seal and pop it out. Should be really easy.
Old Jan 28, 2014 | 05:07 PM
TommiM's Avatar
make sure you are given the correct seals. The local Mitsu dealership kept given me the wrong one every time. The one for the dri and pass side are different iirc. The one they kept giving me was not anywhere close to either of those two.
Old Jan 28, 2014 | 05:12 PM
jhoganusaf's Avatar
yea i ordered OEM seals through STM. got one for drivers and a different part number for the passenger side.
Old Jan 28, 2014 | 09:25 PM
lostsoulsevo's Avatar
Lol Jeremy! We got this, I told you already
BaLListic_EVO
24
Oct 13, 2016 02:59 PM
jdmauto
Aug 6, 2016 06:49 PM
gearheadvr4
Lancer Tranny/Drivetrain Tech
Mar 16, 2016 10:38 PM
JTCB
Apr 8, 2015 02:46 PM
AcePitcher11
17
Feb 4, 2012 10:54 AM
