Huge Problem With Bov!!! Help
Old Dec 5, 2007 | 06:55 PM
  #31
hokiruu's Avatar
Originally Posted by Slo_crx1
Even aftermarket recirc setups are tricky to get setup properly. I had to replace my stock plastic one with a TurboXS Type-H34, and it took quite a while to get the spring tension dialed in properly to make it run and idle like stock. Too stiff of a spring and you get compressor surge, too soft and it opens at higher boost pressure. If you don't have the time or know-how to deal with setting up an aftermarket piece, I highly recommend the metal Evo IX diverter valve. Just get an open element intake like stated if you really want to hear the sound.
^ +1. My Evo came with a Greddy Type S and I used it recirculated. I disassembled, single spring modded, rebuilt with teflon tape etc., then spent 2 hours doing laps on the highway and street getting it right...
and it still only worked right like 90% of the time. I'm running a recirc. IX DV.
bml1024
Feb 6, 2017 11:34 AM
OZRally462
Lancer Engine Tech
Jul 31, 2014 09:46 AM
djlonewulf
May 15, 2013 09:03 AM
ppremier21
May 25, 2012 09:56 AM
maperformance
Aug 25, 2010 03:31 PM
