Interesting Carbonetics Triple Failure
Old Dec 7, 2007 | 02:50 PM
scorke's Avatar
Originally Posted by jmartinez1170
Where are the pics
In your evo.
Scorke
Old Dec 7, 2007 | 05:56 PM
SWOLN's Avatar
...kind of a sidebar, but at what torque did your Exedy Twin slip?
Oh! and pics would be good.
Old Dec 8, 2007 | 07:08 AM
crcain's Avatar
The clutch was relatively low mileage and not much hard usage. Then I got my new setup tuned which was a 2.4 + 35R. Don't have a dyno here though. The tuner estimated I think about 600 ft/lbs torque on race fuel if I recall correctly.
We went to the track for the first time a few weeks ago. We wanted to take it very easy as I've broken a lot of gearboxes and transfer cases lately. Ran an 11.0 first pass with 1.9 60 ft granny shifting. Then ran an 11.0 again with 1.9 60 ft, but this time the clutch slipped when shifting 5th near the end of the 1/4.
We let the car cool down for about 30 min, then made a 3rd and final pass. Car ran a 10.9 and the clutch didn't slip this time around. 1.8 60 ft and still not flat shifting, also lifting early at the end.
Let me upload the pics about my friends ATS triple now...
Old Dec 8, 2007 | 07:34 AM
crcain's Avatar
Ok I went over to friends house last night to check it out. I'm interested in all this because I have a brand new ATS triple sitting here at home that I bought for future use and am now worried about using it. For sure I won't use it without a scatter shield now.
Here are the pics. I forgot to get some pics of the mashed up turbo. If you recall from my original post, a large piece of the bell housing tore through the silicone couple on the turbo intake and mashed up the compressor blades real good.
Pics below:
Old Dec 8, 2007 | 07:37 AM
crcain's Avatar
Old Dec 8, 2007 | 09:08 AM
Mark S's Avatar
Were all the bolts still in the clutch? Could it be they come loose then when they fell out the basket exploded.
Mark
Old Dec 8, 2007 | 09:11 AM
scorke's Avatar
How about more pics of the graffitti car?
Scorke
Old Dec 8, 2007 | 03:10 PM
jmartinez1170's Avatar
The bolts where tq down right its that simple. You have to go around a few time before installing. The few people a i know that have the clutch said they went over the bolts from 6-10 times top insure it was done right one guy has 8k miles countless passes no problem at all.
Old Dec 8, 2007 | 03:12 PM
ACTman's Avatar
Since the flywheel and clutch hat are in place but the ring broke, It looks to me like the bolts came out or broke off. The remnants of the ring will tell the story. If all the bolts are broken off inside, the bolts failed. If there are at least a couple empty holes then the bolts came loose first so it is not the fault of the clutch.
Old Dec 8, 2007 | 08:07 PM
crcain's Avatar
I'll try to find out the answers to those questions guys.
But let me ask, when installing this clutch, you'd never have to touch the bolts holding the basket would you?
Old Dec 9, 2007 | 02:02 AM
wow
Old Dec 9, 2007 | 05:02 AM
crcain's Avatar
wow
Get a clue my friend. This clutch failure I'm posting about was a friend of a friends. I didn't install the clutch. I'm posting this thread cuz I'm curious why it failed as I have a brand new ats triple sitting here waiting to go in my evo.
So your "wow" comment makes no sense.
On top of that, and I'm no expert but, I'm pretty sure the bolts holding the basket to the flywheel do not need to be touched from looking at the clutch. Am I right? (not asking you jmartinez)
Old Dec 9, 2007 | 04:03 PM
crcain's Avatar
FYI
I asked and they said definitely the bolts holding the basket to the flywheel sheared. I'd have taken a pic but I think the pieces of basket are off to ATS to have a looksy.
Old Dec 11, 2007 | 03:13 PM
Geoff Raicer's Avatar
interesting to hear the bolts sheared, im sure ATS will take care of you. i know i always try to use loctite on anything i really dont want coming loose...
this stuff called seal-lock GRIP is amazing, i use it on everything i really dont want coming apart
Old Feb 19, 2008 | 09:54 AM
crcain's Avatar
Another friend with Evo 9 has had his Carbonetics triple EXPLODE. I'll try to get some pics. This is a friend of mine with Full-Race twin scroll GT40 and 2.3 IX RS running Halltech. Apparently this time it has totallly destroyed the gearbox not just the bell housing!
This is a DIFFERENT car to the first failure I reported in this thread.
The first failure I reported was another friend of a friend with a 2 litre Evo 9 and Innovate turbo on a Full-Race mani.
I will concede that, to have this happen to two people I know, without every seeing a post about it elsewhere, that something suspicous might be happening. Maybe mechanic doing something wrong? Hard to say. The two friends do use the same mechanic.
I'll post some pics once I get them.
