Compressor surge
Old Dec 30, 2007 | 12:12 PM
Asmodeus6's Avatar
Check your boost controller.
My stock turbo and 3076 does that at an agressive part throttle. It doesn't do it at wot, or light part throttle. I have switched the bov to 4 different ones, and even switched the turbo and it still does it. My last guess is its the boost controller.
Old Dec 30, 2007 | 12:39 PM
cssaddictm4's Avatar
This happened to my setup all the time if you went WOT in a higher gear at low RPMS. For example, in my MR if you were in 6th and went WOT at 3000rpms it would surge. This is easily solved by down shifting or going WOT near where your turbo is already spooling.
Old Dec 30, 2007 | 12:47 PM
blackdemon's Avatar
Can it be the wastegate spring? or dump tube?
Old Jan 2, 2008 | 04:19 PM
Synapse's Avatar
Weird, it sounds like surge, like air coming out the compressor inlet though. Almost like DV flutter should fix it, but the BOV isn't sensitive enough to open so it is going out the compressor inlet, which is the surge that you don't want.
BTW, it doesn't sound at all like it is leaking.
Old Jan 3, 2008 | 01:28 PM
blackdemon's Avatar
It has the HKS race BOV
Old Jan 3, 2008 | 01:32 PM
Evo Tengoku's Avatar
....same thing happens to me....
Old Jan 3, 2008 | 01:48 PM
fostytou's Avatar
EvoM Community Team
My 2g does that in 5th gear. Make sure your boost controller line is not sourced off the same line that your BOV is connected to. If it is (especially with EBCs) then the tiny bit of air that flows over to the wastegate/atmosphere can cause just enough pressure drop in the top of the BOV for the pressure in the charge pipes to lift it. Use a direct line from post butterfly to the blowoff if possible and make sure it isn't leaking (pressure test or get a new line) as a small crack can cause this also.
Old Jan 18, 2008 | 09:58 PM
zzombae's Avatar
Exactly~!!! It happens on my car as well~! I thought it's because bov can't hold the boost(30+ psi) so I was gonna buy a HKS super sqv Racing BOV..I guess it's not a BOV problem anymore..what exactly is the reason for that?
Old Jan 18, 2008 | 10:01 PM
dsmjeffro's Avatar
vaccume leak or ****ty bov!!!!
Old Jan 18, 2008 | 11:18 PM
riceball777's Avatar
that sounds like bov flutter not compressur surge
Old Jan 19, 2008 | 08:24 PM
90GSXDan's Avatar
I was going to say check your vacuum/boost lines to make sure they are all hooked up to the wastegate and pressure source correctly, Just so you can tell the BOV is actually opening....
Old Jan 20, 2008 | 01:44 AM
zzombae's Avatar
Definately it's not a BOV problem, because that thing happens when under partial boost, not full boost.
Fast4AWD
15
Jan 16, 2012 09:16 AM
pinoy6969
Sep 25, 2011 07:28 AM
revhappy
Jun 13, 2011 07:30 PM
blackonblackevo
10
Jul 7, 2007 05:23 PM
TrinaBabe
Apr 3, 2005 05:48 PM
