Compressor surge
Old Dec 7, 2007 | 03:46 PM
blackdemon's Avatar
Compressor surge
My buddy has a 1995 eagle talon with a DSM FP3065. And at WOT he gets compressor surge. Is it possible that the compressor wheel is loose? Boost leak? What can cause this?
Old Dec 7, 2007 | 03:56 PM
bluebyu36's Avatar
blow off valve or mass air.....maybe just a guess
Old Dec 7, 2007 | 04:05 PM
blackdemon's Avatar
can't be the BOV because it only happens at WOT. And the car does not have a MAS because its running a standalone.
Old Dec 7, 2007 | 04:57 PM
bluebyu36's Avatar
plugs?proably checked that allready though...
Old Dec 8, 2007 | 03:44 PM
Mike@Forge's Avatar
All you need to know.
https://www.evolutionm.net/forums/sh...d.php?t=285733
Old Dec 9, 2007 | 07:35 AM
blackdemon's Avatar
If you had a high flowing cylinder head is it possible to cause compressor surge if the hotside of the turbo is to small?
Old Dec 9, 2007 | 04:44 PM
blackdemon's Avatar
Here is the vid so that you guys can hear it.
Old Dec 30, 2007 | 02:01 AM
85?'s Avatar
85?
My Evo 9 is doing that same thing right now, and I am still trying to find out what the problem is.
Old Dec 30, 2007 | 06:43 AM
blackdemon's Avatar
I think the turbo might need replacement.
Old Dec 30, 2007 | 09:19 AM
MitsuJDM's Avatar
My dad's 1995 GSX does the same thing. He had a Turbonetics BOV, and it did nothing but surge, so he replaced in with a new GReddy (uses the same flange) and it worked for a bit, but it started to surge again. Now it'll work maybe 5% of the time. You go parital boost and shift, it'll work, you go partial boost in the next gear and it'll surge.
It leads me to believe it's not the BOV's fault do to it working on occasion. I'd think if the BOV was roken, which I doubt because it's brand new, it would surge ALL the time. I just don't get it. It surges REAL bad at WOT.
Old Dec 30, 2007 | 09:56 AM
blackdemon's Avatar
If the turbo needed replacement would it do this all the time? He has the stiff spring in his Race HKS BOV. It did not do this when he was running 30psi, it started happening when he turned it down to 15psi
Old Dec 30, 2007 | 10:24 AM
X_Evo's Avatar
my 2 cents
Sounds like flutter from the BOV to me. The valve sounds like it needs to be loosened.
Old Dec 30, 2007 | 11:05 AM
Dapper Dan's Avatar
sounds like a leaky bov
Old Dec 30, 2007 | 11:51 AM
blackdemon's Avatar
It did not leak at 30psi. Why would it leak at half that?
Old Dec 30, 2007 | 12:08 PM
20Grockit's Avatar
it does kinda sound like bov flutter to me as well.
