fitment problem
Old Dec 9, 2007 | 10:48 AM
tnhockey's Avatar
fitment problem
so i just put on my first mod last night...injen intake w/uicp. on the bottom pipe of the uicp it seems to hang down a little low....bc i cant get the front of the undertray back on. so i was jw if thats normal? or if it shud sit flush like it did with the stock uicp. also the bracket on the same pipe didnt seem to line up with anything to bolt it down to.
Old Dec 9, 2007 | 04:33 PM
20Grockit's Avatar
it should bolt up right. the pipe might need to be adjusted in the couplings between the ic and the next pipe coupling. that icp is made to bolt up with no problems.
Old Dec 9, 2007 | 04:42 PM
RedLanEVO's Avatar
the bracket is made to bolt up to a screw hole under where the stock airbox sits. there's a couple bolt holes there, but you just gotta find the right one. as for the undertray, i never had one on when i had this piece so i never knew if it fit the undertray or not. but everything should be bolt up. the hose connecting the uicp and the intercooler, if u still have a stock intercooler, you have to position the coupler differently to get a good fit. thats how i did it. it worked fine with no leaks.
MR EVO 2410
Jun 15, 2017 04:39 PM
Tekniq
Oct 4, 2012 01:14 PM
vipevo9
Mar 17, 2010 11:31 PM
hamx0r
18
Jul 10, 2008 06:42 PM
phabaznbro
13
Jun 8, 2008 12:12 PM
