Will a IX mivec map work on a VIII
Old Dec 13, 2007 | 02:10 PM
PVD04's Avatar
Originally Posted by Thegame
http://evomoto.com/tech_info.php?tPa...dcfeaf66acaeb0
Check out step # 40. I'm not saying to go crazy with the screw, but a turn or two at a time won't hurt. Just make very sure you know where you started, just in case it gets worse.
Probably not a night and day difference, but it's a good starting point.
A turn or two is way too much. If you do adjust the idle screw, I would start with 1/4 turn. Do it with the car off, 1/4 turn counter-clockwise, then start the car and see how it idles. The how-to referenced above was written before Ecuflash was available. Idle can now be adjusted using the idle tables in Ecuflash. If you adjust your idle screw those tables become less usable.
-Paul
