Brian Crower Cams for Evo IX - run untuned?
Old Dec 13, 2007 | 07:25 PM
SavEVOIX's Avatar
Some new Brian Crower cams were ordered for me as a gift today and I had some questions on my install. Can I run these 272 cams without a tune? I currently have TBE, K&N Drop In, EBC, Greddy Type S BOV, Works Flash with small street tune. Only reason I don't want to go get a dyno tune yet is my IX turbo is out of shape due to a bolt randomly falling in my intake (dont ask).
Old Dec 13, 2007 | 07:56 PM
nikkadanny's Avatar
get your turbo fixed and then put cams and a tune
Old Dec 13, 2007 | 08:08 PM
EVIL_EV0's Avatar
If you jacked up your 9 turbo you should turn it into a 20G.
No reason to do 9 cams before a bigger turbo. Its more work and less gain than a Green/20G would provide.
Either way you can run untuned.... you'll still be rich.
Old Dec 14, 2007 | 05:05 AM
randomae's Avatar
I have searched tring to find out what the green turbo that people are refering to is. Is it off an evo 9?
Old Dec 14, 2007 | 05:14 AM
CBRD's Avatar
a green upgrade is worth it, a standard 20g comp wheel is not, in my opinion...
cams are a nice upgrade...
cb
Old Dec 14, 2007 | 07:31 AM
scheides's Avatar
EvoM Moderator
call forced performance, have them rebuild your IX turbo into a green. get the cams installed and the green, and have the car tuned when all is said and done. You will be one happy camper!
Old Dec 14, 2007 | 01:24 PM
Jeff_Jeske's Avatar
I agree with this. The Buschur Racing 20G-LT (large trubine) is the same turbo as the Forced Performance Green turbo.
I also agree that aftermarket mivec cams on the stock turbo is a waste. You shouldn't add cams until you upgrade the turbo and even then they aren't needed.
Cams are good for 10WHP and a 20G-LT is good for 25WHP.
Old Dec 14, 2007 | 01:30 PM
brodienuchies's Avatar
You can run them without a tune but idle will be rough. Those are aggressive cams...
Old Dec 21, 2007 | 08:35 AM
SavEVOIX's Avatar
I plan on going with the TME green but I have also read the turn around time on these things are horrible so i'm trying to buy another stock turbo and sending in my messed up to get worked up.
I also switched to the Brian Crower 280 since i've seen people run them with stock valve train.
guyver858
Sep 9, 2015 10:53 PM
KOOLER
Oct 10, 2011 02:34 PM
MR_EVO21
16
Jul 17, 2008 01:15 PM
evoDON
Feb 18, 2008 06:49 PM
Kins
Dec 17, 2007 02:32 PM
