hotside and turbo
Old Dec 14, 2007 | 04:14 PM
evilevo22's Avatar
hotside and turbo
how do you remove the hotside from the turbo i dont wanna mess up the blades.\
thanks
Old Dec 14, 2007 | 04:17 PM
EvoDan2004's Avatar
slooooooooowly. hammers are bad.
Old Dec 14, 2007 | 04:35 PM
evilevo22's Avatar
any suggestions it aint budgin
Old Dec 14, 2007 | 04:51 PM
gsrboi80's Avatar
Yea man like Dan said carefully pry them apart. I used a screwdirver in the seam and tapped the screwdriver with a hammer
Old Dec 14, 2007 | 04:59 PM
Thegame's Avatar
Be very very careful though. The hotside has some weight to it and as soon as it breaks loose, it could cause some damage. Especially if the O2 housing is still attached. Make sure you're holding on to it. The turbine blades can handle a slight bump or two, but just take your time.
Old Dec 14, 2007 | 05:01 PM
evilevo22's Avatar
thanks
Old Dec 14, 2007 | 07:08 PM
sparky's Avatar
Recruit a helper to assist you in the removal of the hotside as an extra set of hands will prove useful. Use a thin, flat blade srewdriver and work it between the center housing and the turbine housing. The exhaust housing is cast iron and heavier than it looks. It tends to pop off all of a sudden and will crash down onto the turbine blades all of a if you donīt have someone holding onto it. So, be careful.
OhhBx
Nov 8, 2014 05:01 AM
memphis69
Jun 15, 2014 12:34 PM
guzmangjr
25
Nov 15, 2013 08:13 PM
