what intake for 30R ?
Old Dec 16, 2007 | 12:11 PM
turbodreamz21's Avatar
hey guys
im goign 30r soon it will prob be a gt3076r with a .63 a/r most likely 3inch inlet or i could go 4 i have the hks suction intake now and obv that is ot small for 30r so just wondering whos ells intakes for that turbho? and i was just wondering if any of u guys know of what store sells intakes that have a 3-4 inch piping to fit the 30r ?
please help
thanks
Old Dec 16, 2007 | 03:46 PM
bumpppp
Old Dec 16, 2007 | 03:50 PM
34Turbo's Avatar
If you're running stock ecu try to keep it a 3'' intake. It'll make life easier for your tuner.
dsmjeffro's Avatar
slow boy has a 4`` one i have a 3065 kit on my car i use the reg buschur one works fine
Old Dec 16, 2007 | 04:35 PM
so either slow boy or buschur? those shoudl be fine to run the 3 inch
Old Dec 16, 2007 | 04:41 PM
vwjeff's Avatar
My BR intake works great, and when tuned my car it worked like a dream. I got a 3 to 4in coupler
Old Dec 16, 2007 | 04:49 PM
Psquared's Avatar
I was gonna say..most kits come with an intake setup...but couplings will make almost any intake fit...btw vwjeff...looks like a nice setup! ^^
Old Dec 16, 2007 | 05:24 PM
looks great man...right now i have the hks suctiojn intake... the couplers fit around the turbo fine the intake pipe is the same size as the 16g thats why im asking woudl the actually piping be to small to run for a 3 inch 30r??
thnks for help guys
Old Dec 16, 2007 | 06:05 PM
joosdawg's Avatar
i would never use any intake pipe that would be used with the stock turbo unless it is at least 3" in diameter all the way to the inlet. Otherwise thats a serious bottle neck. When i was on my 3076r i had both a 3" and a 4" intake that i made for it. I personally could tell a differnce between the two in terms of flow. Also if you have antisurge compressor housing and you use the 3" intake the reducer you must use to couple the intake pipe and the turbo inlet will block the ports and cause surge for a quick second between shifts. I tested and tested as far as power and power curve with the 3" vs the 4" but when it came down to it my 4" touched the lower radiator hose so i stayed with the perfect fitting 3". If all else fails hit me up with a pm and ill weld one up for you in mild steel and paint it whatever color u like.
Old Dec 16, 2007 | 07:42 PM
9sec9's Avatar
good info joosdawg.
Old Dec 16, 2007 | 07:52 PM
HaVoC RR's Avatar
im using buschur
Old Dec 16, 2007 | 09:29 PM
very nice info joosdawg ill def let u know im hoping to get everything i need for the car a little after x-mas beggining of jan
so i mite take u up on that offer..
i wanted to get ppls insight on it so i know which way to go...
so far this is wat i got for plans...
my current setup is this
Perrin catless turbo-back exhaust
HKS INtake
GSC 272 cams
HKS Cam Gears
SS clutch line
tein s tech springs
Dynoflash
i want to go get a real tune on a dyno for it but i figured ill wait till the 30r comes..
the way i was thinking of going was doing this for my next steps..
AMS FMIC/piping
ACT 6 puck clutch
HPF gt3076r
DNP manifold/ 38mm wastegate
880cc injectors
walbro fuel pump
and obv a tune...but im wondering should i get it flashed first or wait until i have enough money to save for a standalone..
or should i go with halltech or something liek that???
help would be nice guys
Old Dec 17, 2007 | 08:09 AM
joosdawg's Avatar
another thing i should note in the mod list, DO NOT get the 6 puck clutch! You will regret it. The chatter was so bad on mine it backed out two of the three bolts holding the rear motor mount to the tranny. Snapped the cast piece of the mount in half on a launch, broke an axle... Needless to say i got to the point of i didnt even want to drive the car anymore so i ended up putting a stock 5spd mitsu disc in with the ACT HDSS pressure plate and couldnt be happier. Also leave the restrictor pill in or you may have problems with launching.
As far as a stand alone, with all the capabilities of the stock ecu i personally stayed with that and whole heartedly reccomend that. I bought MaftPro to use specifically to run my car on spped density with a Map sensor and GM temp. That way i could ditch the stock maf and have free roam on intake design and bov to use like tial venting to the air without any ill effects. That and full controll over fuel and timing was the main thing i ever wanted a stand alone for in the past. Sense with ecuflash ect you can controll any variable youd ever want, and the tephara mods you can have no lift to shift aswell as a few other goodies, i honestly see no point in going stand alone. Tunability wise, if you want to be able to make adjustments yourself the stock ECU will still have that "save your a$$ mode" which if for some strange reason you really botch a tune trying to up timing for race gas or lean it out you still have the ecu to back you up with knock retard and a very very good system of "not letting you blow your motor" because of it. Whereas with a stand alone, unless your experianced in tuning you have a very high probability of blowing somthing up. That is a great thing for a good tuner as it will do anything and everything that you tell it to do, but on the other hand in terms of going into a novice set of hands that could be your motor in one pull.
DNP manifolds are a great product shouldnt have any problems there. As far as the 38mm wastegate make sure if you go that route that you get an authentic Tial gate or you will be paying in the long run. I cheaped out once and got a turbonetics evolution 38mm wastegate and it boost creeped bad. Also had a buddy with an ebay gate and needless to say the diaphram failed within a year of install.
Dont know what your planning on doing for a downpipe or maybe i didnt read that but if you need any help fabbing a downpipe shoot me a pm aswell as i fabbed my downpipe from ss when i made my kit and it worked great!
Old Dec 17, 2007 | 06:00 PM
ya i have a full 3 inch exhaust form perrin so the Dp is 3 inch my exhaust is cat-less..
thanks for all the information
so u think a 6puck is a bad choice to go im hoping to be putting donw 400+whp after the setup and tuneing is complete i want a clutch to be bale to hold the power fo that
Old Dec 17, 2007 | 06:06 PM
housedj's Avatar
here's an option:
http://www.evo400.co.uk/index.php?ca...4&ProductID=22
