t-case change out
Old Dec 16, 2007 | 06:28 PM
cyberninja's Avatar
t-case change out
What is the whp limit on the stock t-case?
Old Dec 16, 2007 | 06:34 PM
AWD Motorsports's Avatar
there is no limit.. some guys destroy them on 300whp and others last 500whp.. it all depends on how you drive, what clutch and suspension setup etc..
Old Dec 16, 2007 | 06:40 PM
cyberninja's Avatar
I have a fidanza kevlar clutch and flywheel and stock suspension. I making some pretty decent power right now (349 whp/357 ft tq). I know my t-case is going sooner or later because the whining has started. Any inputs on going stock or shep(what stage)?
Old Dec 16, 2007 | 09:20 PM
cyberninja's Avatar
late night bump
Old Dec 16, 2007 | 09:24 PM
MitsuJDM's Avatar
I'm 68k. I can hear slight whine up to 35mph above that I can't hear it. But I must have the windows down and stereo off in order to hear it. It tends to whine a little louder when it's cold. I hope it doesn't go :-/
But anyway, I've heard ot stock t-case working past 500whp. of course with anything else on a car, more power will cause more stress which usually leads to quicker failure. But it'll hold up.
Old Dec 16, 2007 | 09:27 PM
cyberninja's Avatar
Thanks. I would like to get a shep t-case but I don't have the time to install it and some shops charge more than the oil trade to intall it. I'll stick with the mitsu then. thanks again.
Old Dec 16, 2007 | 09:29 PM
best thing to do is call shep and let him know what goals you have with the car as far as WHP etc.. hell advise you of what you need.. in my experience though if you damage your stocker alot of times shep will not rework it and put his name behind the tcase..
Old Dec 17, 2007 | 10:15 AM
randomae's Avatar
is the transfer case the same for all evo 8s and 9s? Including the 6-speed?
Old Dec 17, 2007 | 10:18 AM
TeStUdO's Avatar
No. The 03-04's have open diffs, except for the RS. The 05's and newer are helical.
Old Dec 17, 2007 | 10:20 AM
randomae's Avatar
Are all of the above mentioned transfer cases getting screwed up?
Old Dec 17, 2007 | 10:21 AM
TeStUdO's Avatar
Only when not filled with proper fluid or launched.
Old Dec 17, 2007 | 10:25 AM
randomae's Avatar
Ok i see. So which ones are people having trouble with? The helical cut ones?
Old Dec 17, 2007 | 10:26 AM
TeStUdO's Avatar
This has been covered millions of times..........try searching. Ive given you some good starting points.
Old Dec 17, 2007 | 10:27 AM
randomae's Avatar
Well thanks i'll try to find what i am looking for
