Engine noise?
Old Jan 1, 2008 | 05:24 AM
blackdemon's Avatar
Originally Posted by Peruvian
So i took my car to work and put it on the lift. took out the clips from around my left front tire and saw wat was making the buzzing sound. Its like a black motor looking thing with wat looks like a canistor attached to the side. I disconnected it and the buzzing sound went away. Connected it and it came back. So i know where its coming from i just dont know what that component is called anyone have any clue? Looks like its connected to the intake system
left front tire when standing in front of the car or sitting on the driver seat?
Old Jan 1, 2008 | 06:57 AM
RedV's Avatar
I'm interested in the outcome of this, and what is causing this noise. I've had a similar noise in my IX since it had about 3000 miles on it. I'm now at 25,000 miles (yes, I drive it a lot) and the noise is still there.
I did take it in to the dealer not long after the noise started and their diagnosis was, "If it gets any worse bring it back in. Until then it's nothing major."
Old Jan 4, 2008 | 07:06 PM
mr.romero's Avatar
I took my 9 in yesterday to the dealer for the same issue, sounded just like it does in the clip you provided. I told them it may be the pulley tensioner and the service person told me that they have been having evo 9s come in with that same problem issue. But, of course while I was their for 2 hours my car wouldn't make the noise.
I believe that it takes a while of driving to get the noise to start. Maybe the heat causes something t metal to expand and start rubbing against something else. Either way they told me to bring it in if it starts making that noise again, which it did today after driving home from san diego, which is a 2 hour trip in traffic.
Old Jan 5, 2008 | 05:55 AM
blackdemon's Avatar
The noise comes and goes.
Old Jan 24, 2008 | 02:27 AM
bchappy's Avatar
my 8 does it
whenever the fan comes on and accessory belt moves its like the motor mount is loose...
it knockaround
also if your getting whining that goes away with the clutch pushed in its your TOB
Old Jan 24, 2008 | 03:03 AM
Deepseadiver's Avatar
It seems like that always happens when you take it to the dealer, the sound just goes away.
Old Jan 24, 2008 | 04:17 AM
blackdemon's Avatar
There must be someone who had this checked and fixed by now
Old Feb 7, 2008 | 08:39 PM
blackdemon's Avatar
has anyone checked the cause of this problem yet?
I believe its the pulley on top of the crank pulley that works with the accessory belts. Could I be wrong?
Old Feb 14, 2008 | 05:36 AM
philevo's Avatar
Here is the answer and what to do to get rid of it:
https://www.evolutionm.net/forums/sh...ght=belt+noise
Answer on page 9 and 10.
Old Feb 16, 2008 | 03:03 PM
EVO8emUp's Avatar
Mine sounds like that every once in a while.
Old Feb 16, 2008 | 03:56 PM
blackdemon's Avatar
im going monday to the dealer to get it fixed. Ill keep you guys posted
