Installed/Made Tranny Cooler for my 6 speed.
Old Dec 21, 2007 | 09:44 PM
Sharkbite2000's Avatar
Very nicely done , wanna hear about your results
Old Dec 21, 2007 | 10:14 PM
Kidloco51's Avatar
Originally Posted by ixbreaker
a couple of hundred degrees?...reason why i ask is because the pumps operating temps...and it keeps a constant temp of about 265degF or 130degC....if its beyond these limits the pump could fail....unless the effiency of the cooler keeps it well below this threshold...i guess we wont know until he takes it out to the track
If you noticed the pump goes after the cooler. Tilton makes you do this to maximize life of the pump. I am going to install a temp guage down the road just to see were the temps are.
Old Dec 22, 2007 | 11:55 AM
ixbreaker's Avatar
^should be around 200 or so...do you know what the temps were before the install? tahnx
Old Dec 22, 2007 | 01:41 PM
Redline06's Avatar
Awsome.. this would def. aide those of us that wont to hold on to the 6spd till it pops.
Old Dec 22, 2007 | 01:51 PM
FocusMSP's Avatar
it's bolted on by 3 bolts/nuts on the cross member...look at the first couple of pics.
I don't think the tranny goes that much over 265 Degrees. Great pump, specs according to the manufacturer:
- 1-2 gpm flow rate
- 60 psi (max) working pressure
- 12-volt DC
- 265¾F (constant) temperature capacity
- Self-priming up to 8ft. vertical height
- Internal bypass valve
- Pump head can be rotated 180 degrees
Old Dec 29, 2007 | 05:07 PM
Mike@JTuned's Avatar
Very nice! I've been looking to do something like this. Quick question, are those expanding rubber pieces from the OE license plate brackets?
GJ btw
Old Dec 29, 2007 | 05:17 PM
t51splbb's Avatar
Good job .
Old Dec 29, 2007 | 05:24 PM
Evoryder's Avatar
pretty sick stuff
Old Dec 31, 2007 | 11:17 AM
Kidloco51's Avatar
GJ btw
I purchased those expanding rubber pieces from my local Hardware store. They are a common item.
Old Dec 31, 2007 | 11:51 AM
evokel's Avatar
sweet!
Old Jan 4, 2008 | 06:55 PM
RUFRIDR's Avatar
Those expanding rubber pieces are commonly used to hold Truck bug guards on. Simply hold the bug shield in place with the hood open, push the rubber piece through the bug guard into a factory hole in the hood and tighten the screw. You have to put a good amount of pressure when you tighten them or they'll pop out of the hole before they fully expand.
Kudos on your design. I can't wait to see the results. Does anyone have a temperature reading from a 6-speed tranny w/out a cooler to use as a go by?
Old Jan 4, 2008 | 07:01 PM
alan678's Avatar
So where is the magnet picking up the debris?
Old Jan 5, 2008 | 09:36 AM
nightwalker's Avatar
good point. maybe a filter could be integrated in there.
Old Jan 5, 2008 | 09:59 AM
Ginglingston11's Avatar
damn that install was clean...great job
Old Jan 10, 2008 | 07:00 PM
CBRD's Avatar
we are doing something similar, but in a way to add more capacity, using the same pump though.
very nicely done.
cb
