No Boost in lower gears
Old Dec 20, 2007 | 02:51 PM
choicelaw's Avatar
I have searched and read quite a few posts on boost issues, I don't post alot so here goes.
Mods: K&N drop in, Apex-i WSII catback and XS flash.
Issue: In 1st and 2nd gear I am barely getting any boost even when I get into higher RPMs. Maybe 5-7 psi max. unless WOT, even then maybe 10-12 max?
In 3-5th gear seems to spool and hit 18-19 psi in a normal manner.
I do not have a boost controller at all. I did a visual for any loose hoses, and exhaust leak and do not see any evidence.
Input appreciated.
Old Dec 20, 2007 | 03:15 PM
chaotichoax's Avatar
lower gears = less load
less load = less boost
10-12 in first is pretty normal at wot
Old Dec 31, 2007 | 08:17 AM
Chamama's Avatar
Only 10-12 psi in first? I get 21psi in 1st and 2nd. and 22.5 in 3rd onwards. I have logs if anyone is interested. I haven't touched the boost/vacuum lines.
Old Dec 31, 2007 | 08:27 AM
EVIL_EVO_VIII's Avatar
Keep in mind also that if you do a wot pull from 5-7k rpms or higher, boost will be a lot less than if you nail the gas pedal at 2500-3000 rpms. Youre always gona get less boost in lower gears, specially 1st due to the load..Get yourself a mbc
Old Dec 31, 2007 | 09:51 AM
mitdrx's Avatar
Did you change tires? After I put on snow tires I was just spinning and couldnt get load on the car in 1-3
Old Dec 31, 2007 | 10:15 AM
wkehn's Avatar
Cat converter on the car? If so how old? It may be clogged.
Old Dec 31, 2007 | 04:48 PM
krazirob's Avatar
still should be no excuse to have 5-7 psi at WOT in high revs in first gear..........weird though. make sure all your vacuum lines are still connected. A MBC wouldnt hurt either
Old Dec 31, 2007 | 05:01 PM
Flipbboy03's Avatar
try cleaning ur drop in filter. could b hella dirty.
Old Dec 31, 2007 | 06:00 PM
krazirob's Avatar
man that would suck if that were causing the problem......would have to be extremely NASTY..........EWWWW....lol
Old Dec 31, 2007 | 06:13 PM
kaonashi's Avatar
are you kidding? if you spin your boost is going to spike like crazy.
Go into a field with grass and mash it and tell me if your boost loads while spinning :P
4G63_EVO
Jun 8, 2017 10:02 PM
SOG RA
34
Sep 17, 2015 09:14 PM
wazmunstr
Jun 28, 2014 05:54 AM
GiLizILL
Jan 15, 2009 11:39 AM
heyzeus11
Sep 16, 2006 10:55 PM
