Evo IX with Stage IV - BR Gt3065 Cast manifold 501 whp on pump with alchy
This car previously made 478 with a SNOW performance alchy kit and the alcohol flow was not smooth enough to quell all deonation on spool up
We added an Aquamist HFS 1 and the car is 100% knock count free all the way through the power band on normal 93 octane pump gas at 28 - 29 psi at 501 whp
The car has stock ecu and stock engine - cosworth cams only
Buschur Stage IV and BR Cast manifold GT3065 turbo kit
The customer will take the car for a test drive today and he may chose to upgrade to a HTA GT35 depending on if he feels this is enough speed and power to meet his needs
Here is a short video
http://www.youtube.com/watch?v=RjcpEJYBWko
Deezaang....how could that not be enough........I thought I had an addictive personality
His other car is a
2002 Porsche 996 Turbo - w/ twin Gt3082 Turbos - 3.8 L built motor, cams, pistons, crank, etc etc. 1.5 Bar boost 750 whp
You can understand therefore, that an Evo may "feel" slow to this customer
I am hoping to satisfy his needs for power on his daily driver Evo
Al
Its delivery of alcohol is more suited to the way our cars make power and the needs of a high bosting 2.0 L engine
The HFS 5 is a great system but often we need less alcohol up top and more down low which is the opposite of the HFS 5 configuration. Keep in mind, I do not use alcohol as a subsitute for fuel supply but rather as a tuning aide to supress knock and allow the customer to run more boost on pump gas than would otherwise be possible.
Al
