Meth injection (how much to you use a month?)
Old Dec 30, 2007 | 02:45 PM
  #46
SlowCar's Avatar
Originally Posted by steadly2004
So, do you think I just shouldn't even install it then, if I can't afford a fail safe? and all the other parts?
I will always keep it filled, and not be one of the dumb-dudes who let it run out. My current situation is kinda like this.
1. install the snow performance stage 2 kit and use it until I can upgrade stuff
2. don't install it, and have slightly high intake temps. Retard timing to adjust and loose power.
theres all sorts of failure besides running dry.
-kinked line
-loose power connection
-faulty pump
-line coming lose
the list goes on and on...
here is the most recent incident: https://www.evolutionm.net/forums/sh...d.php?t=315118 - which potentially could have been prevented if the trigger point is set above WG using the aquamist dds3's safety operating window setting the flow lo + flow hi setpoints.
its a risk w/o failsafe...
Old Dec 30, 2007 | 03:31 PM
  #47
EVO8URV8's Avatar
Damn, that sux
Ya, could have been prevented if the trigger point is set above WG using the aquamist dds3's safety operating window setting the flow lo + flow hi setpoints PLUS the zeitronix zt-2.
As for the zt-2, SlowCar, do I still need the ZR-1 gauge for it? Or I can do fine without it?
Old Dec 30, 2007 | 04:04 PM
  #48
SlowCar's Avatar
you can do w/o the display...you do the datalogging on a laptop
eg
[/QUOTE]
Old Dec 30, 2007 | 04:29 PM
  #49
EVO8URV8's Avatar
What u think about "mating" the HFS-5 with Aem Uego instead of the zt-2? Not a good idea?
Old Dec 30, 2007 | 04:37 PM
  #50
TTP Engineering's Avatar
Thats a stupid idea. The AEM is worthless.
The ZEITRONIX is the whole brains behind the safeguards.
Old Dec 30, 2007 | 05:20 PM
  #51
steadly2004's Avatar
HAHAH, i have the AEM UEGO. Why do you say its worthless? It seems to work just fine for me
Old Dec 30, 2007 | 05:21 PM
  #52
EVO8URV8's Avatar
Thanx for letting me know. Glad that I didn't buy the AEM yet.
As for the display of my AFR if I wanna see it on my dash, the ZR-1 should be fine to check it when I don't have the laptop around, rite?
Old Dec 30, 2007 | 06:37 PM
  #53
uSmC_08's Avatar
I too am going to go with the Zeitronix...I just wanted to know from you guys which options I need to purchase with the unit?
Thanks!
Old Dec 30, 2007 | 08:03 PM
  #54
SlowCar's Avatar
Thanks!
get the 3.5MAP sensor and the zavt-1
and then the display if you want bling
Old Jan 2, 2008 | 11:49 PM
  #55
Dyrexion's Avatar
Im doin the same as steadly but im still in the research phase of this upgrade. do those nozzle rings come with the kit. and how exactly did you get em in there. i noticed the clamp ring or whatever bid you make a groove for it??
Im also workin with a 4g64 so my piping is 2"in that part of the piping towards the TB
Old Jan 3, 2008 | 03:41 AM
  #56
SlowCar's Avatar
i'm using the existing groove in the uicp
i put a bevel in one edge of the circlip and there is a centering oring that goes between the axial mount abd the uicp to keep it centered and snug
Old Jan 3, 2008 | 05:11 AM
  #57
I'm just planning on drilling/tapping the pipe, and it'll just spray 90* to the airflow.
Old Jan 3, 2008 | 05:12 AM
  #58
LilRico's Avatar
Well.... damn. I jumped the gun and paid for that kit. I'll have to work with what I got now. Damn. I was looking at getting a larger tank and the failsafe on the Snow site. The only problem is that they don't have the "Safe Injection" that monitors flow right now, but they do have the "low level indicator". I could possibly wire that up to my boost controller to have it run very low boost if the level is low, my only problem is that the signal isn't strong enough. And the "scramble boost" setting gets activated by a ground, not by power. Hmm....I'm sure there is a solution here, I just have to think through it.
Also, I was looking at this
http://www.coolingmist.com/detailmain.aspx?pid=05
But again, it just lights up a light.
I'm a little late, but I already have the safe injection kit from snow performance on me but not installed yet. I had it for about a month or so. I got it from Ultimate CC, including the Low Level Indicator, and the Safe Injection Wastegate Solenoid. Just PM him.
And for how much meth I use a month... Hmmmm... A 5 gallon of VP M1 last me a really long time... 2 months depending how hard I drive it...
Old Jan 3, 2008 | 06:46 AM
  #59
KevinD's Avatar
the AEM UEGO is worthless because it does nothing but display AFR on a gauge. and it does that poorly. the gauge seems to have a very high latency from my experience with it (i've compared them directly against zeitronx, innovative, and widebands on a dyno). also out of the box it cannot even data log with a PC which is one of the biggest reasons for getting a wideband.
Old Jan 3, 2008 | 09:41 AM
  #60
I can data log with EVOscan. All I had to do was solder up a serial cable, and get a serial to usb converter.
And, as for the latency.... I guess I'll just have to suck it up. I can't change stuff now.
