Meth injection (how much to you use a month?)
Ok, so I'm thinking of getting some meth injection, since just throwing in a larger intercooler is very difficult for me to accomplish. My only worry is about how fast will I run through the meth injection.
My car is a 4g64 (working on rebuild at the moment) SOHC I currently have a 3" x 6" x 20" intercooler. I don't think I'm getting the cooling that I need. I was conetmplating getting a liquid intercooler or meth kit.
So....... How much to you guy who drive with meth everyday run through, and how much does it end up costing you in any given period of time. Like do you use a gallon every 2 weeks?
Where do you guys source your Methanol?
only if you are a beast and boost every minute you drive and how you set it to go
on i bought 5 gallons back in september i still have half of that and its 100% if it were 50/50 it will last a little longer
Holy crap, that last alot longer than I thought it would. wow.....
Can you get meth through the mail, or does that like make you go to jail for trying to transport flammable liquids or something crazy like that?
I all depends on how much you mash the gas. Also no matter how much you blast your gas pedal it still will be cheaper then running race fuel.
When running meth make sure you have a failsafe, have proper installation and, have proper tuning or your motor will give up on you! I would search goggle and evom for you questions.
It just pretty much raises the octane right? I mean you can advance your timing a bit to achieve more hp? Is there anything else major to consider when tuning with meth?
Use commonly available tech grade meth, 99% purity.
The VP meth M>1 has additives that will potentially cause issues.
