JM Fabrications Intake Manifold
Old Jan 2, 2008 | 11:34 AM
05-EVO-GSR's Avatar
Originally Posted by Chris@JNZtuning
I'll see if I can find the pic I took. To be honest you're not going to get the optimum benefit of the intake manifold if you're using the stock upper intercooler pipe though.
As for sensors, the EGR provision is removed, as with every other aftermarket intake manifold. Yes, it can be used with the stock ECU.
I agree, but running the stock ECU with the MAF, 91 Octane, etc. is not optimal either. Everything is a compromise but it should work fine.
Do you extend every hose/vacuum hose or are there any that remain the same. How many ports are needed to retain most of the stock hoses?
I should be able to remove the EGR no problem with the JDM MAP Sensor.
Old Jan 2, 2008 | 12:59 PM
11secDSM's Avatar
I agree, it will work..just not optimally. A couple of the vac hoses need to be extended but most don't. The standard amount of vac ports that come with the manifold would be sufficient for you.
Old Jan 2, 2008 | 04:46 PM
nightwalker's Avatar
so how do you prevent the MIL from coming on with the EGR removed? Can a tuner disable the light?
Old Jan 2, 2008 | 05:37 PM
11secDSM's Avatar
I know a couple of the bigger tuners were looking into it but i'm not sure if any of them have found the way to disable the EGR circuit. It's just something everyone with a stock ECU has dealt with that's running an aftermarket manifold.
Old Jan 2, 2008 | 06:23 PM
05-EVO-GSR's Avatar
Chris@JNZTuning,
So what you are saying is if I rotate this hose I can use the stock upper IC pipe with no problems?
Old Jan 3, 2008 | 05:09 PM
05-EVO-GSR's Avatar
ttt
Old Jan 3, 2008 | 06:35 PM
11secDSM's Avatar
Not that coupler...the one in the front of the engine bay. But yes, if you rotate the front coupler the opposite way you can use the stock intercooler pipe.
Old Jan 3, 2008 | 06:38 PM
11secDSM's Avatar
A customer sent me a pic from an install we did yesterday so i'll post that up tomorrow....
Old Jan 4, 2008 | 04:39 PM
05-EVO-GSR's Avatar
Bump for pictures
Old Jan 5, 2008 | 11:41 AM
05-EVO-GSR's Avatar
Bump
I would like to see more pictures so I can buy this manifold for my car.
Old Jan 5, 2008 | 12:34 PM
11secDSM's Avatar
Here's the pic he sent me. I know it's not the best but it shows it installed. If you need more pics i'll have to see if I can get him to come in again.
wasabisnooter
Oct 14, 2010 02:42 AM
bryans2k
20
Jul 4, 2010 03:06 PM
maniak
Oct 16, 2007 02:11 PM
bryans2k
Jul 10, 2004 11:13 PM
lancerozr
Lancer Engine Tech
12
Oct 23, 2003 05:46 PM
