Issue with my new turbo kit (driveability/stuttering, bov??): PLEASE HELP!!!! )
Old Jan 1, 2008 | 05:28 PM
  #31
evilbada's Avatar
I think its the spring on the Tial BOV,
It's not holding boost therefore opening a bit under WOT causing the loss of boost pressure. But strong enough to hold more than 15psi.
Swap your Bov to your previous forge rs then test again.
Old Jan 1, 2008 | 08:12 PM
  #32
dxbevo9's Avatar
i had the same exact problem..on my stock turbo...tried out everything...and at the end i found out that i have set the gain too high on my EBC(greddy profec B-spec II) as well as setting the "limit boost" to my target 1.5bar while the gain was trying to exceed this limit...the limiter was trying to stop it causing it to stutter and bounce back between 1.5bar & 1.2bar causing the car to jerk back an forth and drive like ****..
just as you mentioned, this situation was exajorated when boosting in higher gears from low rpm than it did in lower gears...nonetheless...still did it untill i turned my gain down and turned off the boost limit..
i know you have an MBC...but i just thought i should share.
Old Jan 1, 2008 | 09:16 PM
  #33
04AWDTURBOEVO's Avatar
Originally Posted by Boost3dxEvO
I just put on a turbo kit, along with full bolt ons... here is my mod list:
Precision 57 trim Dual BB Turbo
ETS Tubular Manifold
ETS 3" Downpipe
ETS 3.5" Downpipe Back Exhaust
ETS Short Route LICP
ETS UICP
ETS 3" O2 Housing
ETS Intake
K+N Long Filter
Tial 50mm BOV
MAF Gen 1 Translator
3" GM MAF
Tial 38mm Wastegate (Recirculated)
Walbro 255 Fuel Pump
Precision 780cc Injectors
Hallman Pro MBC
Cosworth M2 Cams
ARP Headstuds
Okay.. onto the problem.... If I am in a high gear with low rpm and do WOT .. as the boost rises to the top (20psi) ... it hits 20psi and AGGRESSIVELY go back and forth between 15psi and 20psi and in between.. and my car stutters like H3LL!!
I used to have the stock MAF with a Forge RS bov and my car would stutter if I was barely on the gas and let off really quick... but this new stuttering is at WOT and is really aggressive.
In the lower gears it is okay, but still ... when I reach full boost (20psi) my boost gauge just hits 20psi and the needle shakes like crazy and goes between 19psi and 20psi.. I really need help!!! PLEASEEEE!!!!!
I really would like to pinpoint the issue.. this is scary to me.
Please help!!!!
I am going to guess here and say that the MAF Gen 1 Translator and 3" GM MAF may be the cause of the problem.
This Mod can be causing the issue.
Get it look at by the person who set it up for you. Could need more fine tuning.
Old Jan 1, 2008 | 09:46 PM
  #34
Boost3dxEvO's Avatar
Originally Posted by kaonashi
def a leak you shouldnt hit fool spool from a roll until around 3500-4k
ETS sends that turbo out with the .63 a/r so its a good size like I said he shouldnt be spooling that soon even with the BB
This is the Spec's on the ETS 57 trim and his should be like this. Unless he said different.
Part Number: SC3431R
Max Rated HP: 545
Inlet/Outlet Size: 3"/2"
Bearing System: Ball Bearing
A/R Ratio: .48, .63 or .82
Garrett Compressor Wheel Trim: 57
Garrett Turbine Wheel Trim: 76
Garrett Compressor Wheel Specs:
Wheel Trim: 57
Wheel Inducer: 2.230" (56mm)
Wheel Exducer: 2.950" (75mm)
Garrett Turbine Wheel Specs:
Wheel Trim: 76
Wheel Style: T31
Wheel Inducer: 2.559" (65mm)
Wheel Exducer: 2.228" (57mm)
ETS's turbos are Precision.. but yes, it is a .63 AR
Old Jan 1, 2008 | 09:50 PM
  #35
I set it up myself and it is fine...
I think I know what is the issue....
I think because my turbo's spool is typically in the low 4000rpms.. that I should not be hitting full boost at 3k in higher gears..
I went out tonight and did some more experimenting..
I found that in ANY gear that this stuttering happens if I am at an EXTREMELY low rpm.. such as 2500-3000 .. besides 1st of course..
The spring on my Tial has already been changed to the 7psi spring (the one Tial recommends for 10 in/hg vacuum).. so it isn't the Tial..
I am just going to stay out of WOT at a low RPM in gears that take FOREVER to spool like 5th and 6th..
Old Jan 2, 2008 | 06:11 AM
  #36
TiALSport's Avatar
it's not
Old Jan 2, 2008 | 07:34 AM
  #37
DTM's Avatar
DTM
No offense , but I am not sure why you are going full throttle at 2500 rpm in 5th let alone 6th gear. Downshift......
Old Jan 2, 2008 | 07:54 AM
  #38
kaonashi's Avatar
HAHA funny guy though you could correct me. But to your supprise that is a Precision 57trim BB turbo.
Part #
SC3431RE
This is 100% the exsact turbo ETS use's for their 57trim.
http://www.precisionturbo.net/small-...bochargers.php
Old Jan 2, 2008 | 03:43 PM
  #39
SickSilverNLow's Avatar
hmmm....i have this kit from ETS and i have no problem what so ever..... Get it to a good shop and have them take a look at it.
Old Jan 2, 2008 | 04:20 PM
  #40
steadly2004's Avatar
I did too when I setup my AEM boost gauge/controller. I had set the crack pressure too high, and the duty cycle too low. It was holding till crack pressure, then opening with the duty cycle that dropped it below crack, and it would catch and the boost would go up and down.
The only thing is that he has a MBC, and that shouldn't be the problem. But it could be. something wrong mechanically with his MBC.... thats my guess.
Old Jan 2, 2008 | 04:47 PM
  #41
kaonashi's Avatar
is your car STUTTERING "Stalling" or fluttering "bov sounds like its a retard" 2 different things here we need to know the exsact thing.
Old Jan 2, 2008 | 06:05 PM
  #42
take a vid and post it......need to know what kind of noise you are hearing. Like is said, i have the turbo kit and i have had no problem at all with mine. Drives like a champ.....
bertVIII
19
Nov 13, 2018 06:41 PM
Atlevox
16
Sep 29, 2012 08:54 PM
ThePresley
Dec 4, 2011 12:07 PM
Boost3dxEvO
Jan 8, 2008 12:48 AM
AllBlak
16
May 29, 2006 04:02 PM
