stock intercooler upperpipe problem...
Old Dec 30, 2007 | 11:51 AM
SLOWRREX's Avatar
I finally got tuned yesterday,and let me first off say..I cant believe i waited so long..F-ing amazing..With that being said..Now the problem..My upper intercooler pipe keeps blowing off..I know evryone is gonna say "go buy an aftermarket one",and im going to..But, i have to wait a few weeks..Ran outta money with Christmas and everything..But, is there a better clamp i can buy??Instead of the crappy stock ones,that might hold better??If so,where can i buy one at??Thanks..Justin
Old Dec 30, 2007 | 11:53 AM
06MREvo's Avatar
Everyone is going to say T bolt clamps and hairspray...haha...
Old Dec 30, 2007 | 11:55 AM
Cali2MDevo8's Avatar
Registered User
Don't need hairspray, but T-bolt clamp is your friend!! I changed over to those when I had my stock pipes and they held like a champ at 23 psi. Good luck
Jason
Old Dec 30, 2007 | 11:59 AM
20Grockit's Avatar
i would have to say t-bolt clamps as well. try machevo, upscale automotive, lancershop. those are just a few. hopefully youll have some luck.
Old Jan 2, 2008 | 04:59 PM
RedLanEVO's Avatar
true that they will not blow off but if you over-tighten t-bolts, they WILL create a leak. it's kinda hard to tell when you've reached a good torque for t-bolts because they don't stop until they reach the bottom of the threads.
i am using stock clamps and am doing 28+psi. no problems with anything blowing off. i just have them tightend to where the rubber hose just kind of flares out. no leaks whatsoever. i've used t-bolts too and have switched them out back to stock clamps. all my problems with leaks were solved after that.
i have noticed that stock clamps can handle more torque than any aftermarket clamps (ie: autoparts store clamps) with the only exception of the goodyear wormdrive clamps. (different design to prevent stripping.)
Old Jan 2, 2008 | 05:01 PM
RedLanEVO's Avatar
another thing...the only place that would really benefit from t-bolts is where the outlet pipe/lower intercooler hose is.
Old Jan 2, 2008 | 05:04 PM
RevMoto's Avatar
LOL can you elaborate on the t bolt clamps making leaks. I didn't know a tighter seal makes leaks. I know that you can bend a lot of cheaper aluminum pipes that way.
Old Jan 2, 2008 | 05:13 PM
EJEvo's Avatar
https://www.evolutionm.net/forums/sh...21#post5036721
Old Jan 2, 2008 | 05:38 PM
CrackerJackToy's Avatar
T-bolt clamps wont hold it if grease or oil is on the intake pipe. If it keeps blowing off with a t-bolt, use brake cleaner to clean the surface off... then spray a lot of hairspray, then tighten clamp. Let it dry & it wont ever pop off again
Old Jan 2, 2008 | 05:44 PM
cfdfireman1's Avatar
The right size T-clamps work great for me, anyone have a solution for the stock hose bulging out and contacting the fan short of after market hoses?
Old Jan 2, 2008 | 06:07 PM
RevMoto's Avatar
You are the first I have heard of that. Make sure all hoses are pushed in far enough. More if you have to. It comes close but not that close.
Old Jan 2, 2008 | 06:14 PM
wizzo 8's Avatar
Might be commen sense but make sure when you tighten the clamp its parallel with the end of the hose. This will give full clamping power.
Devo IX
Mar 21, 2012 07:21 AM
amscrazy
Mar 23, 2008 08:09 PM
EarlQHan
Nov 16, 2005 02:18 PM
zupber4930
Automotosports - Illinois
Mar 25, 2004 05:08 PM
teddy
Sep 29, 2003 11:14 PM
