5th gear grind
Old Mar 15, 2008 | 04:17 PM
  #31
FastAzzEvo's Avatar
Originally Posted by bboypuertoroc
Did you adjust your clutch pedal?
yeah a few different times. I firmly believe it was something with the act clutch/install...
Old May 29, 2008 | 02:49 PM
  #32
abraxas's Avatar
Originally Posted by 06RS
There is a TSB for Grinding on 03-04, I'm not sure if there is one for later models
https://www.evolutionm.net/forums/sh...ight=tsb+grind
Does anyone know if there is a similar TSB for the '05? I've tried searching but haven't been able to find one yet. : /
Old May 29, 2008 | 03:18 PM
  #33
AcePitcher11's Avatar
I have the same problem also....shifting at high rpms from 4th to 5th fast gives me a grind but I just do like everyone else and let the rpms drop a little bit then go to 5th.
Old Aug 12, 2008 | 11:45 AM
  #34
sonicnofadz's Avatar
Just to add to the discussion, finally after 66,000 miles my transmission (stock 03) has started to grind when going into 5th. This happened after a really fast shift from 4th to 5th on a dragstrip. I've really beaten this transmission to death (its been rocking an exedy twin since day one) and only now has begun to show signs of abuse. I've been feeding it pennzoil syncromesh but I think its time to step up to a better synthetic fluid that doesnt wear out so fast. This problem is 100% THE SYNCRONIZER, and has absolutely nothing to do with clutch engagement. The only thing you can do to fix it is have your tranny rebuilt or try a better fluid.
