Inside of a Buschur Racing engine with lots of abuse
Old Jan 3, 2008 | 02:04 PM
  #46
EvoDan2004's Avatar
how much more reliable is a sleaved block over a none sleaved block?? any one of the big evo power guys do this??
Old Jan 3, 2008 | 05:14 PM
  #47
David Buschur's Avatar
I am not going into details on sleeving 4g63's, sorry. For those of you that would buy from me you don't have to worry, we'll do what's best for you. For those of you that won't, figure it our on your own
Old Jan 3, 2008 | 11:38 PM
  #48
Aby@MIL.SPEC's Avatar
the pistons look great!
Old Jan 4, 2008 | 02:39 AM
  #49
LilRico's Avatar
Originally Posted by U2SLO
And this is just another reason to buy a fully built buschur block/head assembly!
You know that's right!!! I'm waiting on mines to jump into my engine bay
Since part #1 I bought from your shop it hasn't stopped working as quoted, and seeing the pistons and bearings in the condition that they're in doesn't surprise me at all David, I know you take care of all your customers .
Old Jan 4, 2008 | 05:45 AM
  #50
chuntington101's Avatar
i cant see sleaving making much differance on the Evo. you are still limited to the cylinder spacings so you are only going to gain a very small amout of extra cc from doing it. also i think you could loose strength. that advangtage of the 4G63 over lets say a sleaved Scooby engine is the fact that the cylinder walls are actually an integeral part of the block. there are no joins or splits it all the same metal. you dont get this with ally blocks.
not saying that they cant be strong if designed right (have a look at the racing Ecotec motors!) but i dont see an advantage in sleaving an iron block.
Chris.
Old Jan 4, 2008 | 07:28 AM
  #51
C6C6CH3vo's Avatar
Are those OEM clearances on the RS, and what oil?
Old Jan 4, 2008 | 08:15 AM
  #52
SloRice's Avatar
You honestly think he's going to answer that question?!?!
and what oil?
He might answer that question.
Old Jan 4, 2008 | 08:54 AM
  #53
duracell55's Avatar
The oil BR recommends is non syntetic 20w50
Old Jan 4, 2008 | 12:53 PM
  #54
Alright, my car is back together. Somewhere through the process of taking it apart and putting it back together I decided rather than freshening it up we'd put in a new engine since it was this close anyway. I've been wanting to run one of our aluminum rod engines and I had one done on the engine stand.
Also, I was incorrect on the mileage on the car, it has just over 9,000 miles on it, not 8,000. Not a big difference but wanted to be clear.
I have another thread with pictures of it put back together with the new header, Tial housing and new alternator. Good stuff.
Thanks for all the interest.
Old Jan 4, 2008 | 01:32 PM
  #55
jrsimon27's Avatar
mr.david congrats on putting your engine back together
Old Jan 4, 2008 | 01:43 PM
  #56
https://www.evolutionm.net/forums/sh...=316723&page=2
Old Jan 4, 2008 | 02:04 PM
  #57
dan l's Avatar
Your used pistons look better than some new pistons I've gotten from some vendors that play kickball with your **** back in the stocking room.
Old Jan 14, 2008 | 08:54 PM
  #58
iCaLiberZ's Avatar
This first one is a picture of all four pistons that came out of our black shop car. This engine was in the car since October of 2006 through October of 2007. It was a 2 liter, has seen over 11,000 rpm, over 50 psi of boost. Quite a bit of dyno time, MANY track passes and this is what was in the car when it ran 8.88 and the 172.4 mph record MPH pass. The engine eventually split a cylinder wall (stock block not hard blocked). We took it apart to change the head gasket and freshen it up and found it cracked.
Those pistons look brand new.
I can't believe how much abuse those have been through and the first thing to give was the Mitsu block.
Old Jan 20, 2008 | 02:57 PM
  #59
vwjeff's Avatar
The EVO seems to be very reliable for up to around 640'ish, never seen one crack at or below that power level. I've seen them over that, 750 hp on our dyno and you can just start to expect it, it's going to happen.
hmmm interesting stuff
Old Jan 20, 2008 | 05:27 PM
  #60
c_penson's Avatar
Mr. Buschur, can you post pics of the blown engine gasket, I'd like to see the extent of the damage from that amount of abuse.
