Just received my Evo Green!
Old Jan 3, 2008 | 02:20 PM
recompile's Avatar
Originally Posted by mdsevo06
The $650 estimate came from the Buschur camp. I'm just wondering what would be the benifit of ordering a new one for $1650, instead of saving a thousand, if there identical?
It's $1000 to upgrade... and there's plenty of reasons that it's worth it to get it new...
a) it's new
b) no downtime for a daily driver
c) I can have the hotside ported & coated at my convenience
d) no wait... the turnaround for upgrades is 6-8 weeks, that's lame
recompile's Avatar
Originally Posted by scheides
Sexy turbo man! Is that hotside ported, or just nice and shiny?
This is as-is from FP, the basic setup, no additions. I'm having it ported & coated before it goes in
Old Jan 3, 2008 | 02:38 PM
04AWDTURBOEVO's Avatar
Enjoy your New Toy, .
Old Jan 3, 2008 | 02:45 PM
EvoIXMR's Avatar
damn, I wish I knew. I have it on order from efffpeee - They said 8 weeks or more backordered You got it in 3 days - WTF, ya know?
Old Jan 3, 2008 | 02:54 PM
evoixbri's Avatar
shamelesscookie you plan on getting cams with this setup? im planning on getting the green as well around march but im really doubting the cams on the 9
Old Jan 3, 2008 | 02:55 PM
recompile's Avatar
Not planning on cams unless I'm really far off my goal
Old Jan 3, 2008 | 03:24 PM
JDMCT9MR's Avatar
Nice turbo!I wish I could get one!
Old Jan 3, 2008 | 03:27 PM
blacksj's Avatar
Nice post up # when you get it installed
Old Jan 3, 2008 | 03:43 PM
20Grockit's Avatar
im gettin a green now as well b/c i just burnt up my stocker
Old Jan 3, 2008 | 03:51 PM
scheides's Avatar
EvoM Moderator
400whp is going to be iffy w/o alky or some way to run high boost...prolly need cams and also ported TB&IM, then if you're still a little ways off, order up an HFS-1 or HFS-5 and you'll be set!
Old Jan 3, 2008 | 03:52 PM
Jim in Tucson's Avatar
Originally Posted by ShamelessCookie
I'm going to find out exactly where I stand with stock turbo, stock manifold, stock turbing housing, stock O2 housing, and stock WGA
Then I'm gonna swap the turbos and all the other parts above, re-tune, and head back to the same dyno within a matter of days so I'll have a good comparison.
Shame,
Good plan. I would ask that when you do your comparo please keep the boost level the same as well. Many EVOGreen threads compare stock turbo at 22psi with EVOGreen at 28psi. Of course the Green is way more HP. DUH!!! I'd like to see how a Green actually performs in a direct comparison at the same boost level.
Thanks...
Old Jan 3, 2008 | 05:20 PM
Originally Posted by Jim in Tucson
Shame,
Thanks...
Here is a Graph that compares the gains on my set-up, with just the addition of the 20GLT and supporting mods, such as injectors, Forge IX actuator and re-tune. 30 psi.
Red/Blue=stock 16G 9.8
Green/Dark blue=20GLT
Pretty nice gains from start to finish. It shows the 20G has very much the same spool characteristics as the stock small VIII 16G..
This was back last year when I first installed it. Same Dyno.
Old Jan 3, 2008 | 05:25 PM
JustDSM's Avatar
That was both turbo's on 30psi?
Old Jan 3, 2008 | 05:32 PM
Yes, both Turbos at same boost, 30~31 psi.
Only change was Injectors, WGA, Tune for 20G, ofcourse.
I wanted to see the gains.
Old Jan 3, 2008 | 05:56 PM
JustDSM's Avatar
Thanks for the reply. Healthy power too.
