Just received my Evo Green!
Old Jan 3, 2008 | 12:47 PM
recompile's Avatar
Paid $1650 shipped, brand new, from Extreme PSI. Ordered on 12/28 with free ground shipping, and received it today (it shipped out immediately).
Looking forward to sending the hotisde out for PPI port & coat, as well as installing my clutch, flywheel, ported/coated ex. manifold & O2 housing, and Forge WGA.
Lofty goals... I want to make 400whp on a Mustang. Not sure if I'll be able to do it with pump or without cams, but we'll see.
Old Jan 3, 2008 | 12:51 PM
MyEvoDream's Avatar
nice shameless keep us posted
Old Jan 3, 2008 | 12:58 PM
zbomb's Avatar
Cool, Where's the closest Mustang in the area?
Old Jan 3, 2008 | 12:59 PM
Spoolin18's Avatar
400whp on a Mustang dyno without cams, on pump gas alone, def. is not feesable.
Old Jan 3, 2008 | 01:02 PM
Mad_SB's Avatar
you beat me to it. It's possible, but only if they are fudging numbers. That is without cams or just on pump gas. Then again, I'm used to our dynodynamics heart breaker.
recompile's Avatar
ESP in Sterline ( www.enhancedstreetperformance.com )
Old Jan 3, 2008 | 01:03 PM
Mad_SB's Avatar
When did fp start putting ID plates on the compressor cover??????
Old Jan 3, 2008 | 01:05 PM
recompile's Avatar
You may be right, but most would think that 12.0 AFR, 27psi, and 6° > 16° of timing on pump gas is not feesable either, but I've run my stock turbo that way without a problem and with zero knock (Shell 93 for the win).
I'm going to find out exactly where I stand with stock turbo, stock manifold, stock turbing housing, stock O2 housing, and stock WGA
Then I'm gonna swap the turbos and all the other parts above, re-tune, and head back to the same dyno within a matter of days so I'll have a good comparison.
Old Jan 3, 2008 | 01:09 PM
06MREvo's Avatar
I'm going to guess you hit somewhere around 360whp on a MD with the mods you have currently and installing, with no cams and pump gas, depending on the tuner.
Old Jan 3, 2008 | 01:26 PM
sliqdaddy91's Avatar
fpgreen and cams FTW...i hope to hit 400whp with that turbo and the list of mods below on pump!
Good luck!
Old Jan 3, 2008 | 01:31 PM
MR Turco's Avatar
Shameless i think we are going to try to plan a dyno day at esp next spring/summer. Let me know if you need a hand with the install.
Old Jan 3, 2008 | 01:38 PM
mdsevo06's Avatar
Can't you just send in your stock IX Turbo to FP for $650, and they'll make it a Green?
Old Jan 3, 2008 | 01:41 PM
MR Turco's Avatar
I think it is closer to a $1000. but yeah from what i have read you can.
Old Jan 3, 2008 | 01:58 PM
mdsevo06's Avatar
The $650 estimate came from the Buschur camp. I'm just wondering what would be the benifit of ordering a new one for $1650, instead of saving a thousand, if there identical?
Old Jan 3, 2008 | 02:07 PM
scheides's Avatar
EvoM Moderator
Sexy turbo man! Is that hotside ported, or just nice and shiny?
