Best season to tune???
Old Jan 4, 2008 | 01:03 PM
Jim in Tucson's Avatar
If boost is kept the same, is it best to tune in the winter or the summer?
It would seem to me that with denser air in the winter, a winter tune should be safe in the summer. However, a summer tune may go lean in the winter. Is my thinking correct?
Yes, I already know that it would be possible to have a separate summer tune and winter tune. I'm just trying to understand how weather affects the EVO ECU.
Thanks...
Old Jan 4, 2008 | 01:07 PM
housedj's Avatar
since ur in AZ (my car's in Chandler) the weather change isn't that drastic enuff to go with separate tunes. i would tune in the summer so u don't have knock issues on the crappy 91octane gas. slightly leaner AFR's in the winter will only make more power since the air is cooler...
Old Jan 4, 2008 | 01:11 PM
Spoolin18's Avatar
Thanks...
Your thinking as far as the winter tune should be safer in the summer is correct. Most people tend to see boost rise a little once winter hits, and simply adjust it back to where it should be. I wouldn't worry about this too much, as it's not going to change drastically where you are personally located.
Old Jan 4, 2008 | 01:15 PM
mr.romero's Avatar
Altitude changes (going from sea level to 5,000 feet) make a much more noticeable difference in car performance then temperature due to air density, or lack their of.
Old Jan 4, 2008 | 01:18 PM
mr.romero's Avatar
Your going to see temp changes all of the time. Just think about how different it is from say, high noon to midnight. It's colder at midnight, but no real reason to have separate tunes for just that reason since the air density is pretty consistent.
Old Jan 4, 2008 | 01:19 PM
Billy@EnglishRacing's Avatar
i prefer to tune once in winter once in summer, plus i retune almost every time i am at the track
Old Jan 4, 2008 | 01:48 PM
housedj's Avatar
i would also give IA a call. they do alot of tuning in ur area & may be able to shed a lil more expertise...
http://www.iaperformance.com/contact_us.php
Heccnj92
Oct 25, 2015 06:06 PM
silverevo05
Nov 20, 2013 10:15 PM
Mitsubater
Jul 31, 2011 05:56 PM
theFLASH12
Oct 24, 2010 03:52 PM
dtrackstar
E85 / Ethanol
Mar 9, 2010 11:36 AM
