P0446 - Evap Emission Control System Vent Circuit Malf
Old Jun 9, 2009 | 02:35 PM
Jacoby's Avatar
bump.. having the same issue. anyone else fix this problem? if so how..
Old Jun 10, 2009 | 11:26 AM
Jacoby's Avatar
anybody? I will give you $5 and a snickers bar if you help
Old Sep 28, 2009 | 10:16 AM
Jacoby's Avatar
Thumbs up
Sooooo..
By searching the **** out of this place and finding both the service manual instructions and suggestions on the ecuflash forum.. I finally "fixed" my cel caused by P0446..
I took out every solonoid and tested it and they were all ok.. The wiring was also good. (service manual has you check these.)
So it had to be the ecu.
To fix this I ordered the elusive and out of stock tactrix 2.0 and used openecu to change the base flash..
I had to set FCA periphery bit 15 to 0 and did the emissions hack found here..
The only problem is that I think it worked too good.. It makes the car pass every test and a talented inspector will catch it.. Per my original inspection sheet the EVO should list the following tests as not supported.. With the hack they came up as "ready"
Secondary Air system - should be not supported
A/C refrigerant - should be not supported
Heated catalyst - should be not supported
Anyway I am back on the road and hope this helps someone with the same issue.
fostytou
359
Oct 23, 2025 09:54 AM
fireroasted
Aug 31, 2013 09:52 AM
Nic Money
Mar 22, 2012 12:20 AM
mrfred
Aug 17, 2011 01:30 AM
BadazzCR
Aug 23, 2008 07:40 AM
