How much boost can a stock evo 8 can handle?
Old Jan 9, 2008 | 01:08 AM
evo86's Avatar
Hi,
I have set mine up at 1.53bar (around 22psi) and there seem to be no problem.
what's the boost level that stock evo8 can handle?
I'm running on 98 octane
Old Jan 9, 2008 | 01:22 AM
s2krn's Avatar
What mods... are you tuned, stand alone, what year, stock internals.... come on man give us something to work with.
Old Jan 9, 2008 | 04:54 AM
NYEvoguy's Avatar
+1....We need to know your mods.
Old Jan 9, 2008 | 04:57 AM
Ev0cRaZy's Avatar
Depends on Mods, Octane Gas, Tune...
Old Jan 9, 2008 | 07:06 AM
EvoJoeIX's Avatar
why are there a bunch of these max boost topics?
and no one ever gives any information in them
Old Jan 9, 2008 | 07:42 AM
newbieEVO8's Avatar
Originally Posted by evo86
Hi,
Are you sure that is 1.53?
Much metric boost gauges go 1.5, 1.6, 1.7, 1.8, 1.9, then 2 bar.
Double check that cause you may be running 1.8 bar which is ~26psi.
Old Jan 9, 2008 | 08:24 AM
CRX2EVO's Avatar
too many noobs, that's why
Old Jan 9, 2008 | 10:00 AM
V.8MR's Avatar
about 53psi. But you will have danger to teh manifold. Make sure you upgrade your egr also, they have a tendency to explode!
Old Jan 9, 2008 | 10:09 AM
scoob2evo's Avatar
Stock internals are only rated to 450 at the crank.... be carefull
Old Jan 9, 2008 | 10:10 AM
V.8MR's Avatar
pshhhh
Old Jan 9, 2008 | 10:26 AM
CRX2EVO's Avatar
more than you can afford pal
Old Jan 9, 2008 | 10:36 AM
Eric Keely's Avatar
So what is the stock max boost for a 2003 Evo 8, with no mods?
Old Jan 9, 2008 | 10:37 AM
evo86's Avatar
Coz I'm reading off an electronic gauge, 1.53bar is correct.
It currently has BOV and HKS filter running on 98 octane.
Since stock evo is 19psi (1.31bar), I'm just thinking how much boost evo can handle without further mod.
1.53bar seems to be running fine but you reckon I could go abit higher?
Old Jan 9, 2008 | 10:42 AM
V.8MR's Avatar
Stock. Why raise it if you are all stock.
Old Jan 9, 2008 | 11:10 AM
theblue's Avatar
Hi,
obviously you're not going to feel any problems, your car is probably pulling timing and in reality you are slower then stock.
also, when you run higher octane gas then your car was tuned for it's pretty much going to do nothing.
