clutch help
Old Jan 10, 2008 | 08:13 PM
EVOLV3D's Avatar
Exclamation clutch help
i have a 2006 evo ix mr and im doing a clutch job, i need to get the top three transfer case bolts out but cant seem to get to them at a point at which i can break them loose, what have you guys done to get them off? 2nd what all needs to be done with the acd to do a clutch job?
Old Jan 11, 2008 | 09:37 AM
EVOLV3D's Avatar
anybody?
Old Jan 11, 2008 | 09:41 AM
TeStUdO's Avatar
I used air tools for those three as they are tough to get to.
TTP Engineering's Avatar
It sounds like the clutch job is way out of your league if you have these questions after you already started.
Old Jan 11, 2008 | 09:43 AM
ny-quiL's Avatar
ratchet with extension + pipe on the end of the ratchet
Yes this can be done on jack stands, but on a lift it would be much easier.
Old Jan 11, 2008 | 09:49 AM
E VOL IX's Avatar
yup ... stick a long long extension throught the passanger side fender use a impact gun and get someone under the hood to put your swivel socket on the bolts.... easy enough... when you get done... get someone in the car to bleed the acd... turn the key on then put the gas on the floor.. open the bleeder on the acd and you will hear the pump cut on and ATF will come out,.... when it is all fluid coming out close the bleeder and your all set.
Old Jan 11, 2008 | 09:51 AM
ny-quiL's Avatar
oh..and trans fluid sucks ***. smells terrible and tastes just as bad
Old Jan 11, 2008 | 05:03 PM
EVOLV3D's Avatar
thanks for the help, from what ive read isnt there a way to deal with the acd without having to bleed it?
Old Jan 13, 2008 | 02:10 PM
EVOLV3D's Avatar
HELP!!! i cant get the bolt closest to the engine block on the top of the transfer case out, there is literally no way to get to it, i really need some help here, THIS IS URGENT
Old Jan 13, 2008 | 04:59 PM
EVOLV3D's Avatar
ok, not sure that this is holding the transfer case on, i believe that it is a bolt that holds the trans to the engine block, it is a 14mm bolt
Old Jan 14, 2008 | 07:27 PM
EVOLV3D's Avatar
well i still cant get my transfer case loose, from what ive seen there is only two bolts up top and three on the bottom, i really need some input here people, i need to get this bastard off ASAP!!!!!!
Old Jan 14, 2008 | 07:37 PM
Duh Panda's Avatar
there are three bolts on top.... one is a veryy veryy long one and would be closest to you... the other two are a bit back further .... which one do you need left?
Old Jan 14, 2008 | 07:52 PM
EVOLV3D's Avatar
i have the two on the very top out, is it the same for a 8 and a 9 as far as the locations of the bolts? can you maybe send me a pic of what bolt i have left to take out?
Old Jan 14, 2008 | 08:14 PM
yangs4ever2008's Avatar
Let me help you
I don't know if anybody has told you but there is a site where it'll tell you the how's step by step!
here it goes
http://evomoto.com/tech_info.php?tec...f01d07f1f29a45
This site helped me ALOT!! Without it, I would never of had done this in my garage...I would've took it to the shop instead. It was my first time also! Good luck my friend..
Old Jan 15, 2008 | 06:19 AM
EVOLV3D's Avatar
theres only one problem, i have a IX and the bolt all the way to the left in the picture is not on my car
